REST API reference
Retrieve a Kerberos interface
Retrieves a Kerberos interface to access its configuration details, which is useful for managing authentication settings in your network.
HTTP method and endpoint
GET /protocols/nfs/kerberos/interfaces/{interface.uuid}
Introduced in
ONTAP 9.6
  • vserver nfs kerberos interface show
interface.uuid
string
path
True
Network interface UUID
  • Introduced in: 9.7
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
enabled
boolean
Specifies if Kerberos is enabled.
encryption_types
array[string]
interface
interface
Network interface
spn
string
Service principal name. Valid in PATCH.
svm
svm
      "href": "/api/resourcelink"
  "encryption_types": [
    "string"
  "interface": {
    "ip": {
      "address": "10.10.10.7"
    "name": "lif1",
  "spn": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ip
IP information
address
string
IPv4 or IPv6 address
interface
Network interface
_links
_links
ip
ip
IP information
name
string
The name of the interface.
uuid
string
The UUID that uniquely identifies the interface.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
