REST API reference
Retrieve a Kerberos interface
GET /protocols/nfs/kerberos/interfaces/{interface.uuid}
Introduced In: 9.6
Retrieves a Kerberos interface.
  • vserver nfs kerberos interface show
interface.uuid
string
path
True
Network interface UUID
  • Introduced in: 9.7
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
enabled
boolean
Specifies if Kerberos is enabled.
encryption_types
array[string]
interface
interface
Network interface
machine_account
string
Specifies the machine account to create in Active Directory.
spn
string
Service principal name. Valid in PATCH.
svm
svm
      "href": "/api/resourcelink"
  "encryption_types": [
    "string"
  "force": true,
  "interface": {
    "ip": {
      "address": "10.10.10.7"
    "name": "lif1",
  "machine_account": "string",
  "spn": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ip
IP information
address
string
IPv4 or IPv6 address
interface
Network interface
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
