Retrieve the S3 group configuration for an SVM
Retrieves the S3 group configuration for a Storage Virtual Machine (SVM) to understand and manage the group settings associated with S3 protocols.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/groups/{id}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the S3 group configuration of an SVM.
Related ONTAP commands
vserver object-store-server group show
Learn more
id |
string |
path |
True |
Group identifier that identifies the unique group. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
comment |
string |
Can contain any additional information about the group being created or modified. |
id |
integer |
Specifies a unique group ID used to identify a particular group. This parameter should not be specified in the POST method. A group ID is automatically generated and it is retrieved using the GET method. Group id is SVM scoped. |
name |
string |
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
policies |
array[policies] |
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies. |
svm |
users |
array[users] |
Specifies the list of users who belong to the group. |
"comment": "Admin group",
"id": 5,
"name": "Admin-Group",
"policies": [
"href": "/api/resourcelink"
"name": "Policy1"
"svm": {
"name": "svm1",
"users": [
"name": "user-1"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
policies
_links |
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
users
_links |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
