REST API reference
Retrieve an S3 group configuration for an SVM
Retrieves the S3 group configuration for a Storage Virtual Machine (SVM) to understand and manage the group settings associated with S3 protocols.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/groups/{id}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the S3 group configuration of an SVM.
  • vserver object-store-server group show
id
string
path
True
Group identifier that identifies the unique group.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
comment
string
Can contain any additional information about the group being created or modified.
id
integer
Specifies a unique Group ID used to identify a particular group. This parameter should not be specified in the POST or PATCH method. A Group ID is automatically generated and it is retrieved using the GET method. Group ID is SVM-scoped.
name
string
Specifies the name of the group. A group name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
policies
array[policies]
Specifies a list of policies that are attached to the group. The wildcard character "*" is a valid value for specifying all policies.
svm
svm
users
array[users]
Specifies the list of users who belong to the group.
  "comment": "Admin group",
  "id": 5,
  "name": "Admin-Group",
  "policies": [
          "href": "/api/resourcelink"
      "name": "Policy1"
  "svm": {
    "name": "svm1",
  "users": [
      "name": "user-1"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
policies
_links
_links
name
string
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
_links
_links
name
string
uuid
string
users
_links
_links
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
