REST API reference
Retrieve the S3 server configuration for all SVMs
Retrieves the S3 server configuration for all storage virtual machines (SVMs) to provide information about how S3 services are set up across your environment. You might use this when assessing or verifying S3 configurations for compliance or troubleshooting purposes.
HTTP method and endpoint
GET /protocols/s3/services
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 server configuration for all SVMs. Note that in order to retrieve S3 bucket policy conditions, 'fields' option should be set to '**'.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • statistics.*
  • metric.*
  • vserver object-store-server show
metric.duration
string
query
False
Filter by metric.duration
  • Introduced in: 9.8
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.status
string
query
False
Filter by metric.status
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
secure_port
integer
query
False
Filter by secure_port
enabled
boolean
query
False
Filter by enabled
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.status
string
query
False
Filter by statistics.status
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
is_https_enabled
boolean
query
False
Filter by is_https_enabled
name
string
query
False
Filter by name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
users.svm.uuid
string
query
False
Filter by users.svm.uuid
users.svm.name
string
query
False
Filter by users.svm.name
users.access_key
string
query
False
Filter by users.access_key
users.name
string
query
False
Filter by users.name
users.comment
string
query
False
Filter by users.comment
buckets.logical_used_size
integer
query
False
Filter by buckets.logical_used_size
buckets.svm.uuid
string
query
False
Filter by buckets.svm.uuid
buckets.svm.name
string
query
False
Filter by buckets.svm.name
buckets.protection_status.destination.is_ontap
boolean
query
False
Filter by buckets.protection_status.destination.is_ontap
  • Introduced in: 9.10
buckets.protection_status.destination.is_cloud
boolean
query
False
Filter by buckets.protection_status.destination.is_cloud
buckets.protection_status.is_protected
boolean
query
False
Filter by buckets.protection_status.is_protected
buckets.volume.uuid
string
query
False
Filter by buckets.volume.uuid
buckets.volume.name
string
query
False
Filter by buckets.volume.name
buckets.uuid
string
query
False
Filter by buckets.uuid
buckets.role
string
query
False
Filter by buckets.role
buckets.encryption.enabled
boolean
query
False
Filter by buckets.encryption.enabled
buckets.audit_event_selector.permission
string
query
False
Filter by buckets.audit_event_selector.permission
buckets.audit_event_selector.access
string
query
False
Filter by buckets.audit_event_selector.access
buckets.comment
string
query
False
Filter by buckets.comment
buckets.policy.statements.effect
string
query
False
Filter by buckets.policy.statements.effect
buckets.policy.statements.actions
string
query
False
Filter by buckets.policy.statements.actions
buckets.policy.statements.conditions.operator
string
query
False
Filter by buckets.policy.statements.conditions.operator
buckets.policy.statements.conditions.prefixes
string
query
False
Filter by buckets.policy.statements.conditions.prefixes
buckets.policy.statements.conditions.max_keys
integer
query
False
Filter by buckets.policy.statements.conditions.max_keys
buckets.policy.statements.conditions.source_ips
string
query
False
Filter by buckets.policy.statements.conditions.source_ips
buckets.policy.statements.conditions.usernames
string
query
False
Filter by buckets.policy.statements.conditions.usernames
buckets.policy.statements.conditions.delimiters
string
query
False
Filter by buckets.policy.statements.conditions.delimiters
buckets.policy.statements.sid
string
query
False
Filter by buckets.policy.statements.sid
buckets.policy.statements.resources
string
query
False
Filter by buckets.policy.statements.resources
buckets.policy.statements.principals
string
query
False
Filter by buckets.policy.statements.principals
buckets.qos_policy.uuid
string
query
False
Filter by buckets.qos_policy.uuid
buckets.qos_policy.min_throughput_iops
integer
query
False
Filter by buckets.qos_policy.min_throughput_iops
buckets.qos_policy.max_throughput_iops
integer
query
False
Filter by buckets.qos_policy.max_throughput_iops
buckets.qos_policy.min_throughput_mbps
integer
query
False
Filter by buckets.qos_policy.min_throughput_mbps
buckets.qos_policy.name
string
query
False
Filter by buckets.qos_policy.name
buckets.qos_policy.max_throughput_mbps
integer
query
False
Filter by buckets.qos_policy.max_throughput_mbps
buckets.name
string
query
False
Filter by buckets.name
buckets.size
integer
query
False
Filter by buckets.size
comment
string
query
False
Filter by comment
certificate.uuid
string
query
False
Filter by certificate.uuid
certificate.name
string
query
False
Filter by certificate.name
port
integer
query
False
Filter by port
is_http_enabled
boolean
query
False
Filter by is_http_enabled
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_service]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "buckets": [
          "audit_event_selector": {
            "access": "string",
            "permission": "string"
          "comment": "S3 bucket.",
          "logical_used_size": 0,
          "name": "bucket1",
          "policy": {
            "statements": [
                "actions": [
                  "GetObject",
                  "PutObject",
                  "DeleteObject",
                  "ListBucket"
                "conditions": [
                    "delimiters": [
                    "max_keys": [
                      1000
                    "operator": "ip_address",
                    "prefixes": [
                      "pref"
                    "source_ips": [
                      "1.1.1.1",
                      "1.2.2.0/24"
                    "usernames": [
                      "user1"
                "effect": "allow",
                "principals": [
                  "user1",
                  "group/grp1"
                "resources": [
                  "bucket1",
                  "bucket1/*"
                "sid": "FullAccessToUser1"
          "qos_policy": {
            "max_throughput_iops": 10000,
            "max_throughput_mbps": 500,
            "min_throughput_iops": 2000,
            "min_throughput_mbps": 500,
            "name": "performance",
          "role": "string",
          "size": 1677721600,
          "svm": {
            "name": "svm1",
          "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
          "volume": {
            "name": "volume1",
      "certificate": {
        "name": "cert1",
      "comment": "S3 server",
      "metric": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25T11:20:13Z"
      "name": "Server-1",
      "statistics": {
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "svm": {
        "name": "svm1",
      "users": [
          "access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
          "comment": "S3 user",
          "name": "user-1",
          "svm": {
            "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
Audit event selector allows you to specify access and permission types to audit.
access
string
Specifies read and write access types.
permission
string
Specifies allow and deny permission types.
encryption
enabled
boolean
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket.
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters
array[string]
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
max_keys
array[integer]
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
operator
string
Condition operator that is applied to the specified condition key.
prefixes
array[string]
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
source_ips
array[string]
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
usernames
array[string]
An array of usernames that a current user in the context is evaluated against using the condition operators.
s3_bucket_policy_statement
Specifies information about a single access permission.
actions
array[string]
conditions
array[s3_bucket_policy_condition]
Specifies bucket policy conditions.
effect
string
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
principals
array[string]
resources
array[string]
sid
string
Specifies the statement identifier used to differentiate between statements.
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
statements
array[s3_bucket_policy_statement]
Specifies bucket access policy statement.
destination
is_cloud
boolean
Specifies whether a bucket is protected within the Cloud.
is_ontap
boolean
Specifies whether a bucket is protected within ONTAP.
  • Default value: 1
  • readOnly: 1
protection_status
Specifies attributes of bucket protection.
destination
destination
is_protected
boolean
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud.
  • Default value: 1
  • readOnly: 1
qos_policy
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
_links
_links
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
comment
string
Can contain any additional information about the bucket being created or modified.
encryption
encryption
logical_used_size
integer
Specifies the bucket logical used size up to this point.
name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
policy
policy
protection_status
protection_status
qos_policy
qos_policy
role
string
Specifies the role of the bucket.
size
integer
Specifies the bucket size in bytes; ranges from 80MB to 64TB.
svm
svm
uuid
string
Specifies the unique identifier of the bucket.
volume
volume
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
s3_user
This is a container of S3 users.
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
svm
s3_service
Specifies the S3 server configuration.
_links
self_link
buckets
array[s3_bucket]
certificate
certificate
comment
string
Can contain any additional information about the server being created or modified.
enabled
boolean
Specifies whether the S3 server being created or modified should be up or down.
is_http_enabled
boolean
Specifies whether HTTP is enabled on the S3 server being created or modified. By default, HTTP is disabled on the S3 server.
is_https_enabled
boolean
Specifies whether HTTPS is enabled on the S3 server being created or modified. By default, HTTPS is enabled on the S3 server.
metric
metric
name
string
Specifies the name of the S3 server. A server name can contain 1 to 253 characters using only the following combination of characters':' 0-9, A-Z, a-z, ".", and "-".
port
integer
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80.
secure_port
integer
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443.
statistics
statistics
svm
svm
users
array[s3_user]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
