Retrieve the S3 server configuration for all SVMs
Retrieves the S3 server configuration for all Storage Virtual Machines (SVMs) to understand and manage the S3 settings across your environment. This can help ensure consistency and compliance with your data storage policies.
HTTP method and endpoint
GET /protocols/s3/services
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 server configuration for all SVMs. Note that in order to retrieve S3 bucket policy conditions, 'fields' option should be set to '**'.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
vserver object-store-server show
Learn more
max_key_time_to_live |
string |
query |
False |
Filter by max_key_time_to_live
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid
certificate.name |
string |
query |
False |
Filter by certificate.name
is_https_enabled |
boolean |
query |
False |
Filter by is_https_enabled
min_lock_retention_period |
string |
query |
False |
Filter by min_lock_retention_period
comment |
string |
query |
False |
Filter by comment
port |
integer |
query |
False |
Filter by port
default_win_user |
string |
query |
False |
Filter by default_win_user
default_unix_user |
string |
query |
False |
Filter by default_unix_user
statistics.latency_raw.read |
integer |
query |
False |
Filter by statistics.latency_raw.read
statistics.latency_raw.other |
integer |
query |
False |
Filter by statistics.latency_raw.other
statistics.latency_raw.total |
integer |
query |
False |
Filter by statistics.latency_raw.total
statistics.latency_raw.write |
integer |
query |
False |
Filter by statistics.latency_raw.write
statistics.iops_raw.read |
integer |
query |
False |
Filter by statistics.iops_raw.read
statistics.iops_raw.other |
integer |
query |
False |
Filter by statistics.iops_raw.other
statistics.iops_raw.total |
integer |
query |
False |
Filter by statistics.iops_raw.total
statistics.iops_raw.write |
integer |
query |
False |
Filter by statistics.iops_raw.write
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.status |
string |
query |
False |
Filter by statistics.status
max_lock_retention_period |
string |
query |
False |
Filter by max_lock_retention_period
is_http_enabled |
boolean |
query |
False |
Filter by is_http_enabled
metric.duration |
string |
query |
False |
Filter by metric.duration
metric.latency.read |
integer |
query |
False |
Filter by metric.latency.read
metric.latency.other |
integer |
query |
False |
Filter by metric.latency.other
metric.latency.total |
integer |
query |
False |
Filter by metric.latency.total
metric.latency.write |
integer |
query |
False |
Filter by metric.latency.write
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp
metric.status |
string |
query |
False |
Filter by metric.status
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read
metric.iops.read |
integer |
query |
False |
Filter by metric.iops.read
metric.iops.other |
integer |
query |
False |
Filter by metric.iops.other
metric.iops.total |
integer |
query |
False |
Filter by metric.iops.total
metric.iops.write |
integer |
query |
False |
Filter by metric.iops.write
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
users.name |
string |
query |
False |
Filter by users.name
users.svm.uuid |
string |
query |
False |
Filter by users.svm.uuid |
users.svm.name |
string |
query |
False |
Filter by users.svm.name |
users.access_key |
string |
query |
False |
Filter by users.access_key |
users.keys.id |
integer |
query |
False |
Filter by users.keys.id
users.keys.access_key |
string |
query |
False |
Filter by users.keys.access_key
users.keys.expiry_time |
string |
query |
False |
Filter by users.keys.expiry_time
users.keys.time_to_live |
string |
query |
False |
Filter by users.keys.time_to_live
users.comment |
string |
query |
False |
Filter by users.comment
users.key_expiry_time |
string |
query |
False |
Filter by users.key_expiry_time
users.key_time_to_live |
string |
query |
False |
Filter by users.key_time_to_live
buckets.size |
integer |
query |
False |
Filter by buckets.size
buckets.svm.uuid |
string |
query |
False |
Filter by buckets.svm.uuid |
buckets.svm.name |
string |
query |
False |
Filter by buckets.svm.name |
buckets.role |
string |
query |
False |
Filter by buckets.role
buckets.lifecycle_management.rules.expiration.expired_object_delete_marker |
boolean |
query |
False |
Filter by buckets.lifecycle_management.rules.expiration.expired_object_delete_marker
buckets.lifecycle_management.rules.expiration.object_age_days |
integer |
query |
False |
Filter by buckets.lifecycle_management.rules.expiration.object_age_days
buckets.lifecycle_management.rules.expiration.object_expiry_date |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.expiration.object_expiry_date
buckets.lifecycle_management.rules.object_filter.size_greater_than |
integer |
query |
False |
Filter by buckets.lifecycle_management.rules.object_filter.size_greater_than
buckets.lifecycle_management.rules.object_filter.tags |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.object_filter.tags
buckets.lifecycle_management.rules.object_filter.prefix |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.object_filter.prefix
buckets.lifecycle_management.rules.object_filter.size_less_than |
integer |
query |
False |
Filter by buckets.lifecycle_management.rules.object_filter.size_less_than
buckets.lifecycle_management.rules.enabled |
boolean |
query |
False |
Filter by buckets.lifecycle_management.rules.enabled
buckets.lifecycle_management.rules.bucket_name |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.bucket_name
buckets.lifecycle_management.rules.name |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.name
buckets.lifecycle_management.rules.svm.uuid |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.svm.uuid
buckets.lifecycle_management.rules.svm.name |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.svm.name
buckets.lifecycle_management.rules.abort_incomplete_multipart_upload.after_initiation_days |
integer |
query |
False |
Filter by buckets.lifecycle_management.rules.abort_incomplete_multipart_upload.after_initiation_days
buckets.lifecycle_management.rules.uuid |
string |
query |
False |
Filter by buckets.lifecycle_management.rules.uuid
buckets.lifecycle_management.rules.non_current_version_expiration.non_current_days |
integer |
query |
False |
Filter by buckets.lifecycle_management.rules.non_current_version_expiration.non_current_days
buckets.lifecycle_management.rules.non_current_version_expiration.new_non_current_versions |
integer |
query |
False |
Filter by buckets.lifecycle_management.rules.non_current_version_expiration.new_non_current_versions
buckets.versioning_state |
string |
query |
False |
Filter by buckets.versioning_state
buckets.name |
string |
query |
False |
Filter by buckets.name
buckets.allowed |
boolean |
query |
False |
Filter by buckets.allowed
buckets.audit_event_selector.access |
string |
query |
False |
Filter by buckets.audit_event_selector.access
buckets.audit_event_selector.permission |
string |
query |
False |
Filter by buckets.audit_event_selector.permission
buckets.logical_used_size |
integer |
query |
False |
Filter by buckets.logical_used_size |
buckets.comment |
string |
query |
False |
Filter by buckets.comment
buckets.snapshot_policy.name |
string |
query |
False |
Filter by buckets.snapshot_policy.name
buckets.snapshot_policy.uuid |
string |
query |
False |
Filter by buckets.snapshot_policy.uuid
buckets.volume.name |
string |
query |
False |
Filter by buckets.volume.name |
buckets.volume.uuid |
string |
query |
False |
Filter by buckets.volume.uuid |
buckets.policy.statements.resources |
string |
query |
False |
Filter by buckets.policy.statements.resources
buckets.policy.statements.sid |
string |
query |
False |
Filter by buckets.policy.statements.sid
buckets.policy.statements.actions |
string |
query |
False |
Filter by buckets.policy.statements.actions
buckets.policy.statements.conditions.source_ips |
string |
query |
False |
Filter by buckets.policy.statements.conditions.source_ips
buckets.policy.statements.conditions.if_match |
string |
query |
False |
Filter by buckets.policy.statements.conditions.if_match
buckets.policy.statements.conditions.object_creation_operation |
boolean |
query |
False |
Filter by buckets.policy.statements.conditions.object_creation_operation
buckets.policy.statements.conditions.prefixes |
string |
query |
False |
Filter by buckets.policy.statements.conditions.prefixes
buckets.policy.statements.conditions.delimiters |
string |
query |
False |
Filter by buckets.policy.statements.conditions.delimiters
buckets.policy.statements.conditions.max_keys |
integer |
query |
False |
Filter by buckets.policy.statements.conditions.max_keys
buckets.policy.statements.conditions.operator |
string |
query |
False |
Filter by buckets.policy.statements.conditions.operator
buckets.policy.statements.conditions.usernames |
string |
query |
False |
Filter by buckets.policy.statements.conditions.usernames
buckets.policy.statements.conditions.if_none_match |
boolean |
query |
False |
Filter by buckets.policy.statements.conditions.if_none_match
buckets.policy.statements.effect |
string |
query |
False |
Filter by buckets.policy.statements.effect
buckets.policy.statements.principals |
string |
query |
False |
Filter by buckets.policy.statements.principals
buckets.nas_path |
string |
query |
False |
Filter by buckets.nas_path
buckets.cors.rules.allowed_methods |
string |
query |
False |
Filter by buckets.cors.rules.allowed_methods
buckets.cors.rules.max_age_seconds |
integer |
query |
False |
Filter by buckets.cors.rules.max_age_seconds
buckets.cors.rules.allowed_origins |
string |
query |
False |
Filter by buckets.cors.rules.allowed_origins
buckets.cors.rules.id |
string |
query |
False |
Filter by buckets.cors.rules.id
buckets.cors.rules.expose_headers |
string |
query |
False |
Filter by buckets.cors.rules.expose_headers
buckets.cors.rules.allowed_headers |
string |
query |
False |
Filter by buckets.cors.rules.allowed_headers
buckets.qos_policy.uuid |
string |
query |
False |
Filter by buckets.qos_policy.uuid
buckets.qos_policy.min_throughput_mbps |
integer |
query |
False |
Filter by buckets.qos_policy.min_throughput_mbps
buckets.qos_policy.max_throughput_mbps |
integer |
query |
False |
Filter by buckets.qos_policy.max_throughput_mbps
buckets.qos_policy.min_throughput_iops |
integer |
query |
False |
Filter by buckets.qos_policy.min_throughput_iops
buckets.qos_policy.min_throughput |
string |
query |
False |
buckets.qos_policy.name |
string |
query |
False |
Filter by buckets.qos_policy.name
buckets.qos_policy.max_throughput_iops |
integer |
query |
False |
Filter by buckets.qos_policy.max_throughput_iops
buckets.qos_policy.max_throughput |
string |
query |
False |
buckets.encryption.enabled |
boolean |
query |
False |
Filter by buckets.encryption.enabled |
buckets.is_nas_path_mutable |
boolean |
query |
False |
Filter by buckets.is_nas_path_mutable
buckets.type |
string |
query |
False |
Filter by buckets.type
buckets.protection_status.destination.is_cloud |
boolean |
query |
False |
Filter by buckets.protection_status.destination.is_cloud
buckets.protection_status.destination.is_external_cloud |
boolean |
query |
False |
Filter by buckets.protection_status.destination.is_external_cloud
buckets.protection_status.destination.is_ontap |
boolean |
query |
False |
Filter by buckets.protection_status.destination.is_ontap
buckets.protection_status.is_protected |
boolean |
query |
False |
Filter by buckets.protection_status.is_protected
buckets.uuid |
string |
query |
False |
Filter by buckets.uuid |
buckets.retention.mode |
string |
query |
False |
Filter by buckets.retention.mode
buckets.retention.default_period |
string |
query |
False |
Filter by buckets.retention.default_period
buckets.is_consistent_etag |
boolean |
query |
False |
Filter by buckets.is_consistent_etag
buckets.snapshot_restore.objects_remaining |
integer |
query |
False |
Filter by buckets.snapshot_restore.objects_remaining
buckets.snapshot_restore.progress |
integer |
query |
False |
Filter by buckets.snapshot_restore.progress
buckets.snapshot_restore.snapshot |
string |
query |
False |
Filter by buckets.snapshot_restore.snapshot
buckets.snapshot_restore.state |
string |
query |
False |
Filter by buckets.snapshot_restore.state
name |
string |
query |
False |
Filter by name
enabled |
boolean |
query |
False |
Filter by enabled |
bucket_create_retention_mode |
string |
query |
False |
Filter by bucket_create_retention_mode
secure_port |
integer |
query |
False |
Filter by secure_port
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_service] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"bucket_create_retention_mode": "governance",
"buckets": [
"audit_event_selector": {
"access": "string",
"permission": "string"
"comment": "S3 bucket.",
"cors": {
"rules": [
"allowed_headers": [
"x-amz-request-id"
"allowed_methods": [
"PUT",
"DELETE"
"allowed_origins": [
"http://www.example.com"
"expose_headers": [
"x-amz-date"
"id": "string",
"max_age_seconds": 1024
"lifecycle_management": {
"rules": [
"abort_incomplete_multipart_upload": {
"bucket_name": "bucket1",
"expiration": {
"object_age_days": 100,
"object_expiry_date": "2039-09-23 00:00:00 +0000"
"name": "string",
"non_current_version_expiration": {
"object_filter": {
"prefix": "/logs",
"size_greater_than": 10240,
"size_less_than": 10485760,
"tags": [
"project1=projA",
"project2=projB"
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
"logical_used_size": 0,
"name": "bucket1",
"nas_path": "/",
"policy": {
"statements": [
"actions": [
"GetObject",
"PutObject",
"DeleteObject",
"ListBucket"
"conditions": [
"delimiters": [
"if_match": [
"true"
"max_keys": [
1000
"operator": "ip_address",
"prefixes": [
"pref"
"source_ips": [
"1.1.1.1",
"1.2.2.0/24"
"usernames": [
"user1"
"effect": "allow",
"principals": [
"user1",
"group/grp1",
"nasgroup/group1"
"resources": [
"bucket1",
"bucket1/*"
"sid": "Full_Access_To_User1!"
"qos_policy": {
"max_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"retention": {
"default_period": "P10Y",
"mode": "governance"
"role": "string",
"size": 214748364800,
"snapshot_policy": {
"name": "default-1weekly",
"uuid": "3675af31-431c-12fa-114a-20675afebc12"
"snapshot_restore": {
"snapshot": "string",
"state": "string"
"svm": {
"name": "svm1",
"type": "s3",
"use_mirrored_aggregates": true,
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"versioning_state": "enabled",
"volume": {
"name": "volume1",
"certificate": {
"name": "string",
"comment": "S3 server",
"default_unix_user": "string",
"default_win_user": "string",
"max_key_time_to_live": "PT6H3M",
"max_lock_retention_period": "P10Y",
"metric": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 +0000"
"min_lock_retention_period": "P10Y",
"name": "Server-1",
"port": 80,
"secure_port": 443,
"statistics": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
"users": [
"access_key": "<AWS-ACCESS-KEY-ID>",
"comment": "S3 user",
"key_expiry_time": "2024-01-01 00:00:00 +0000",
"key_id": 1,
"key_time_to_live": "PT6H3M",
"keys": [
"expiry_time": "2024-01-01 00:00:00 +0000",
"id": 1,
"time_to_live": "PT6H3M"
"name": "user-1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
Audit event selector allows you to specify access and permission types to audit.
access |
string |
Specifies read and write access types. |
permission |
string |
Specifies allow and deny permission types. |
rules
Information about the CORS rule of an S3 bucket.
_links |
allowed_headers |
array[string] |
An array of HTTP headers allowed in the cross-origin requests. |
allowed_methods |
array[string] |
An array of HTTP methods allowed in the cross-origin requests. |
allowed_origins |
array[string] |
List of origins from where a cross-origin request is allowed to originate from for the S3 bucket. |
expose_headers |
array[string] |
List of extra headers sent in the response that customers can access from their applications. |
id |
string |
Bucket CORS rule identifier. The length of the name can range from 0 to 256 characters. |
max_age_seconds |
integer |
The time in seconds for your browser to cache the preflight response for the specified resource. |
cors
Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully.
rules |
array[rules] |
Specifies an object store bucket CORS rule. |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. This field cannot be specified in a POST method. |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
_links |
integer |
Number of days of initiation after which uploads can be aborted. |
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links |
boolean |
Cleanup object delete markers. |
object_age_days |
integer |
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date. |
string |
Specific date from when objects can expire. This cannot be used with object_age_days. |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links |
integer |
Number of latest non-current versions to be retained. |
non_current_days |
integer |
Number of days after which non-current versions can be deleted. |
object_filter
Specifies a way to filter objects within a bucket.
_links |
prefix |
string |
A prefix that is matched against object-names within a bucket. |
size_greater_than |
integer |
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied. |
size_less_than |
integer |
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied. |
tags |
array[string] |
An array of key-value paired tags of the form |
svm
Specifies the name of the SVM where this bucket exists.
_links |
name |
string |
uuid |
string |
rules
Information about the lifecycle management rule of a bucket.
_links |
abort_incomplete_multipart_upload |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags. |
bucket_name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
enabled |
boolean |
Specifies whether or not the associated rule is enabled. |
expiration |
Specifies a way to perform expiration action on filtered objects within a bucket. |
name |
string |
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters. |
non_current_version_expiration |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket. |
object_filter |
Specifies a way to filter objects within a bucket. |
svm |
Specifies the name of the SVM where this bucket exists. |
uuid |
string |
Specifies the unique identifier of the bucket. |
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
rules |
array[rules] |
Specifies an object store lifecycle management policy. |
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters |
array[string] |
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified. |
if_match |
array[string] |
Controls conditional writes via If-Match header, evaluated with the Null operator; indicates whether the If-Match header is present or not. |
if_none_match |
boolean |
Controls conditional writes via If-None-Match header, evaluated with the Null operator; indicates whether the If-None-Match header is present or not. |
max_keys |
array[integer] |
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified. |
boolean |
Controls object creation requests, evaluated with the Bool operator; indicates whether it is an object-creation request or not. |
operator |
string |
Condition operator that is applied to the specified condition key. |
prefixes |
array[string] |
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified. |
source_ips |
array[string] |
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified. |
usernames |
array[string] |
An array of usernames that a current user in the context is evaluated against using the condition operators. |
s3_bucket_policy_statement
Specifies information about a single access permission.
actions |
array[string] |
conditions |
array[s3_bucket_policy_condition] |
Specifies bucket policy conditions. |
effect |
string |
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Specifies the statement identifier used to differentiate between statements. The SID length can range from 1 to 256 characters. |
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
statements |
array[s3_bucket_policy_statement] |
Specifies bucket access policy statement. |
destination
is_cloud |
boolean |
Specifies whether a bucket is protected within the Cloud. This field cannot be specified using a POST method. |
is_external_cloud |
boolean |
Specifies whether a bucket is protected on external Cloud providers. This field cannot be specified using a POST method. |
is_ontap |
boolean |
Specifies whether a bucket is protected within ONTAP. This field cannot be specified using a POST method.
protection_status
Specifies attributes of bucket protection.
destination |
is_protected |
boolean |
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud. This field cannot be specified using a POST method.
qos_policy
Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
_links |
max_throughput |
string |
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
min_throughput |
string |
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH. |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
retention
Specifies the retention mode and default retention period configured on the bucket.
default_period |
string |
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "P |
mode |
string |
The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking. |
snapshot_policy
Specifies the bucket snapshot policy.
name |
string |
Specifies the name of the snapshot policy. |
uuid |
string |
Specifies the unique identifier of the snapshot policy. |
snapshot_restore
Specifies information regarding a snapshot restore operation on the bucket
objects_remaining |
integer |
Remaining objects to be restored for the bucket |
progress |
integer |
Snapshot restore progress in percent |
snapshot |
string |
Name of the snapshot being restored for the bucket |
state |
string |
Snapshot restore state of the bucket |
svm
_links |
name |
string |
uuid |
string |
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
allowed |
boolean |
If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service. This field cannot be specified in a POST method. |
audit_event_selector |
Audit event selector allows you to specify access and permission types to audit. |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
cors |
Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully. |
encryption |
boolean |
Specifies whether the NAS bucket returns a consistent ETag across different S3 requests. |
boolean |
Specifies whether the NAS bucket mapping or association with a NAS volume can change according to the changes in the NAS volume junction-path due to volume operations like mount and unmount and therefore the NAS bucket will have access to any path in a NAS volume that matches the specified nas-path. Or is immutable and therefore the NAS bucket will always have access to the same nas-path that was specified during bucket creation even if the volume junction-path has undergone changes after the bucket creation. |
lifecycle_management |
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects. |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. This field cannot be specified using a POST or PATCH method. |
name |
string |
nas_path |
string |
Specifies the NAS path to which the nas bucket corresponds to. |
policy |
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied. |
protection_status |
Specifies attributes of bucket protection. |
qos_policy |
Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached. |
retention |
Specifies the retention mode and default retention period configured on the bucket. |
role |
string |
Specifies the role of the bucket. This field cannot be specified using a POST method. |
size |
integer |
Specifies the bucket size in bytes; ranges from 100GB to 60PB. |
snapshot_policy |
Specifies the bucket snapshot policy. |
snapshot_restore |
Specifies information regarding a snapshot restore operation on the bucket |
svm |
type |
string |
Specifies the bucket type. Valid values are "s3"and "nas". |
uuid |
string |
versioning_state |
string |
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
keys
Specifies a key associated with an S3 user. At most only two keys can be associated with a user.
access_key |
string |
Specifies the access key for the user. |
expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
id |
integer |
Specifies an S3 user key identifier. Each user can only have a maximum of two keys. The key_id can either be '1' or '2'. |
time_to_live |
string |
Indicates the time period from when this parameter is specified:
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
key_id |
integer |
Specifies the identifier of an S3 user key that needs to be generated or deleted. The key_id can either be '1' or '2'. |
key_time_to_live |
string |
keys |
array[keys] |
Specifies the keys associated with an S3 User. |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
s3_service
Specifies the S3 server configuration.
_links |
string |
The default lock mode that will be applied to a S3 bucket when the bucket is created using S3 API. |
buckets |
array[s3_bucket] |
certificate |
Specifies the certificate that will be used for creating HTTPS connections to the S3 server. |
comment |
string |
Can contain any additional information about the server being created or modified. |
default_unix_user |
string |
Specifies the default UNIX user for NAS Access. |
default_win_user |
string |
Specifies the default Windows user for NAS Access. |
enabled |
boolean |
Specifies whether the S3 server being created or modified should be up or down. |
is_http_enabled |
boolean |
Specifies whether HTTP is enabled on the S3 server being created or modified. By default, HTTP is disabled on the S3 server. |
is_https_enabled |
boolean |
Specifies whether HTTPS is enabled on the S3 server being created or modified. By default, HTTPS is enabled on the S3 server. |
string |
Indicates the maximum time period that an S3 user can specify for the 'key_time_to_live' property.
string |
Specifies the maximum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "P |
metric |
Performance numbers, such as IOPS latency and throughput, for SVM protocols. |
string |
Specifies the minimum value that can be set as the retention period for an object in a bucket with locking enabled. The value for this property can be in years or days, not both. The value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "P |
name |
string |
Specifies the name of the S3 server. A server name can contain 3 to 253 characters using only the following combination of characters':' 0-9, A-Z, a-z, ".", and "-". |
port |
integer |
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. Valid values range from 1 to 65535. |
secure_port |
integer |
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. Valid values range from 1 to 65535. |
statistics |
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. |
svm |
users |
array[s3_user] |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
