REST API reference
Retrieve the administrative audit log viewer
Accesses the administrative audit log viewer to review audit logs for administrative activities.
HTTP method and endpoint
GET /security/audit/messages
Introduced in
ONTAP 9.6
Usage notes
Retrieves the administrative audit log viewer.
scope
string
query
False
Filter by scope
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
user
string
query
False
Filter by user
timestamp
string
query
False
Filter by timestamp
input
string
query
False
Filter by input
state
string
query
False
Filter by state
location
string
query
False
Filter by location
message
string
query
False
Filter by message
session_id
string
query
False
Filter by session_id
command_id
string
query
False
Filter by command_id
svm.name
string
query
False
Filter by svm.name
application
string
query
False
Filter by application
index
integer
query
False
Filter by index
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[security_audit_log]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "application": "string",
      "command_id": "string",
      "index": 0,
      "input": "string",
      "location": "string",
      "message": "string",
      "node": {
        "name": "node1",
      "scope": "string",
      "session_id": "string",
      "state": "string",
      "svm": {
        "name": "string"
      "timestamp": "string",
      "user": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
Node where the audit message resides.
_links
_links
name
string
uuid
string
svm
This is the SVM through which the user connected.
name
string
security_audit_log
_links
_links
application
string
This identifies the "application" by which the request was processed.
command_id
string
This is the command ID for this request. Each command received on a CLI session is assigned a command ID. This enables you to correlate a request and response.
index
integer
Internal index for accessing records with same time/node. This is a 64 bit unsigned value.
input
string
The request.
location
string
This identifies the location of the remote user. This is an IP address or "console".
message
string
This is an optional field that might contain "error" or "additional information" about the status of a command.
node
node
scope
string
Set to "svm" when the request is on a data SVM; otherwise set to "cluster".
session_id
string
This is the session ID on which the request is received. Each SSH session is assigned a session ID. Each http/ontapi/snmp request is assigned a unique session ID.
state
string
State of of this request.
svm
svm
timestamp
string
Log entry timestamp. Valid in URL
user
string
Username of the remote user.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
