Retrieve the administrative audit log viewer
Retrieves the administrative audit log viewer to examine logged actions for auditing purposes. This helps you monitor administrative activities and ensure compliance with security policies.
HTTP method and endpoint
GET /security/audit/messages
Introduced in
ONTAP 9.6
user |
string |
query |
False |
Filter by user |
svm.name |
string |
query |
False |
Filter by svm.name |
index |
integer |
query |
False |
Filter by index |
application |
string |
query |
False |
Filter by application |
input |
string |
query |
False |
Filter by input |
state |
string |
query |
False |
Filter by state |
scope |
string |
query |
False |
Filter by scope |
message |
string |
query |
False |
Filter by message |
session_id |
string |
query |
False |
Filter by session_id |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
location |
string |
query |
False |
Filter by location |
command_id |
string |
query |
False |
Filter by command_id |
timestamp |
string |
query |
False |
Filter by timestamp |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[security_audit_log] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"application": "string",
"command_id": "string",
"index": 0,
"input": "string",
"location": "string",
"message": "string",
"node": {
"name": "node1",
"scope": "string",
"session_id": "string",
"state": "string",
"svm": {
"name": "string"
"timestamp": "string",
"user": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
Node where the audit message resides.
_links |
name |
string |
uuid |
string |
svm
This is the SVM through which the user connected.
name |
string |
security_audit_log
_links |
application |
string |
This identifies the "application" by which the request was processed. |
command_id |
string |
This is the command ID for this request. Each command received on a CLI session is assigned a command ID. This enables you to correlate a request and response. |
index |
integer |
Internal index for accessing records with the same time and node. This is a 64 bit unsigned value that is used to order the audit log messages before they are displayed. If multiple entries for the same node and timestamp occur simultaneously, the index assigns an order to ensure logical consistency. |
input |
string |
The request. |
location |
string |
This identifies the location of the remote user. This is an IP address or "console". |
message |
string |
This is an optional field that might contain "error" or "additional information" about the status of a command. |
node |
Node where the audit message resides. |
scope |
string |
Set to "svm" when the request is on a data SVM; otherwise set to "cluster". |
session_id |
string |
This is the session ID on which the request is received. Each SSH session is assigned a session ID. Each http/ontapi/snmp request is assigned a unique session ID. |
state |
string |
State of of this request. |
svm |
This is the SVM through which the user connected. |
timestamp |
string |
Log entry timestamp. Valid in URL |
user |
string |
Username of the remote user. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
