REST API reference
Retrieve public keys configured for a user account
Retrieves the public keys that are configured for a user account. This is useful for managing authentication and access control within your ONTAP environment.
HTTP method and endpoint
GET /security/authentication/publickeys/{owner.uuid}/{account.name}/{index}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the public keys configured for a user account.
  • security login publickey show
owner.uuid
string
path
True
Account owner UUID
account.name
string
path
True
User account name
index
integer
path
True
Index number for the public key (where there are multiple keys for the same account).
  • Max value: 99
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
account
account_reference
comment
string
Optional comment for the public key.
index
integer
obfuscated_fingerprint
string
The obfuscated fingerprint for the public key (READONLY).
owner
owner
Owner name and UUID that uniquely identifies the public key.
public_key
string
The public key
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
The SHA fingerprint for the public key (READONLY).
      "href": "/api/resourcelink"
  "account": {
    "name": "joe.smith"
  "comment": "string",
  "obfuscated_fingerprint": "string",
  "owner": {
    "name": "svm1",
  "public_key": "string",
  "scope": "string",
  "sha_fingerprint": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
account_reference
_links
_links
name
string
User account
owner
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
