Retrieve public keys configured for a user account
Retrieves the public keys that are configured for a user account. This is useful for managing authentication and access control within your ONTAP environment.
HTTP method and endpoint
GET /security/authentication/publickeys/{owner.uuid}/{account.name}/{index}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the public keys configured for a user account.
Related ONTAP commands
security login publickey show
Learn more
owner.uuid |
string |
path |
True |
Account owner UUID |
account.name |
string |
path |
True |
User account name |
index |
integer |
path |
True |
Index number for the public key (where there are multiple keys for the same account).
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
account |
certificate |
string |
Optional certificate for the public key. |
certificate_details |
string |
The details present in the certificate (READONLY). |
certificate_expired |
string |
The expiration details of the certificate (READONLY). |
certificate_revoked |
string |
The revocation details of the certificate (READONLY). |
comment |
string |
Optional comment for the public key. |
index |
integer |
Index number for the public key (where there are multiple keys for the same account). |
obfuscated_fingerprint |
string |
The obfuscated fingerprint for the public key (READONLY). |
owner |
Owner name and UUID that uniquely identifies the public key. |
public_key |
string |
The public key |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
sha_fingerprint |
string |
The SHA fingerprint for the public key (READONLY). |
"href": "/api/resourcelink"
"account": {
"name": "joe.smith"
"certificate": "string",
"certificate_details": "string",
"certificate_expired": "string",
"certificate_revoked": "string",
"comment": "string",
"obfuscated_fingerprint": "string",
"owner": {
"name": "svm1",
"public_key": "string",
"scope": "string",
"sha_fingerprint": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
account_reference
_links |
name |
string |
User account |
owner
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
