REST API reference
Retrieves a specific ca certificate configured for ipsec
GET /security/ipsec/ca-certificates/{certificate.uuid}
Introduced In: 9.10
Retrieves a specific CA certificate configured for IPsec.
  • security ipsec ca-certificate show
certificate.uuid
string
path
True
UUID of the IPsec CA certificate.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
certificate
certificate
IPsec CA certificate UUID
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
  "certificate": {
        "href": "/api/resourcelink"
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
_links
_links
uuid
string
Certificate UUID
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
