Retrieve a CA certificate configured for IPsec
Retrieves a specific CA certificate configured for IPsec to view its details and manage security configurations.
HTTP method and endpoint
GET /security/ipsec/ca-certificates/{certificate.uuid}
Introduced in
ONTAP 9.10
Related ONTAP commands
security ipsec ca-certificate show
certificate.uuid |
string |
path |
True |
UUID of the IPsec CA certificate. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
certificate |
IPsec CA certificate UUID |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
"certificate": {
"href": "/api/resourcelink"
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
_links |
uuid |
string |
Certificate UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
