Retrieve a collection of disks
Retrieves a collection of disks, accessing detailed information about the available disks in your storage environment. This helps you manage and monitor disk resources effectively.
HTTP method and endpoint
GET /storage/disks
Introduced in
ONTAP 9.6
Related ONTAP commands
storage disk show
Learn more
aggregates.uuid |
string |
query |
False |
Filter by aggregates.uuid |
aggregates.name |
string |
query |
False |
Filter by aggregates.name |
sector_count |
integer |
query |
False |
Filter by sector_count
container_type |
string |
query |
False |
Filter by container_type |
vendor |
string |
query |
False |
Filter by vendor |
dr_node.name |
string |
query |
False |
Filter by dr_node.name |
dr_node.uuid |
string |
query |
False |
Filter by dr_node.uuid |
drawer.id |
integer |
query |
False |
Filter by drawer.id |
drawer.slot |
integer |
query |
False |
Filter by drawer.slot |
paths.wwpn |
string |
query |
False |
Filter by paths.wwpn
paths.port_type |
string |
query |
False |
Filter by paths.port_type
paths.wwnn |
string |
query |
False |
Filter by paths.wwnn
paths.initiator |
string |
query |
False |
Filter by paths.initiator
paths.port_name |
string |
query |
False |
Filter by paths.port_name
shelf.uid |
string |
query |
False |
Filter by shelf.uid |
rpm |
integer |
query |
False |
Filter by rpm |
error.reason.arguments.message |
string |
query |
False |
Filter by error.reason.arguments.message
error.reason.arguments.code |
string |
query |
False |
Filter by error.reason.arguments.code
error.reason.message |
string |
query |
False |
Filter by error.reason.message
error.reason.code |
string |
query |
False |
Filter by error.reason.code
error.reason.target |
string |
query |
False |
Filter by error.reason.target
error.type |
string |
query |
False |
Filter by error.type
bay |
integer |
query |
False |
Filter by bay |
class |
string |
query |
False |
Filter by class |
effective_type |
string |
query |
False |
Filter by effective_type
usable_size |
integer |
query |
False |
Filter by usable_size |
pool |
string |
query |
False |
Filter by pool |
model |
string |
query |
False |
Filter by model |
name |
string |
query |
False |
Filter by name |
uid |
string |
query |
False |
Filter by uid |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
rated_life_used_percent |
integer |
query |
False |
Filter by rated_life_used_percent |
key_id.data |
string |
query |
False |
Filter by key_id.data
key_id.fips |
string |
query |
False |
Filter by key_id.fips
fips_certified |
boolean |
query |
False |
Filter by fips_certified
outage.reason.arguments.message |
string |
query |
False |
Filter by outage.reason.arguments.message
outage.reason.arguments.code |
string |
query |
False |
Filter by outage.reason.arguments.code
outage.reason.message |
string |
query |
False |
Filter by outage.reason.message
outage.reason.code |
string |
query |
False |
Filter by outage.reason.code
outage.reason.target |
string |
query |
False |
Filter by outage.reason.target
outage.persistently_failed |
boolean |
query |
False |
Filter by outage.persistently_failed
type |
string |
query |
False |
Filter by type |
stats.iops_total |
integer |
query |
False |
Filter by stats.iops_total
stats.path_error_count |
integer |
query |
False |
Filter by stats.path_error_count
stats.power_on_hours |
integer |
query |
False |
Filter by stats.power_on_hours
stats.average_latency |
integer |
query |
False |
Filter by stats.average_latency
stats.throughput |
integer |
query |
False |
Filter by stats.throughput
local |
boolean |
query |
False |
Filter by local
protection_mode |
string |
query |
False |
Filter by protection_mode
bytes_per_sector |
integer |
query |
False |
Filter by bytes_per_sector
state |
string |
query |
False |
Filter by state |
home_node.uuid |
string |
query |
False |
Filter by home_node.uuid |
home_node.name |
string |
query |
False |
Filter by home_node.name |
serial_number |
string |
query |
False |
Filter by serial_number |
self_encrypting |
boolean |
query |
False |
Filter by self_encrypting
firmware_version |
string |
query |
False |
Filter by firmware_version |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[disk] |
"next": {
"href": "/api/resourcelink"
"records": [
"aggregates": [
"name": "aggr1",
"bay": 1,
"bytes_per_sector": 520,
"class": "solid_state",
"container_type": "spare",
"dr_node": {
"name": "node1",
"effective_type": "vmdisk",
"encryption_operation": "string",
"error": [
"reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"type": "notallflashdisk"
"firmware_version": "NA51",
"home_node": {
"name": "node1",
"key_id": {
"data": "string",
"fips": "string"
"model": "X421_HCOBE450A10",
"name": "1.0.1",
"node": {
"name": "node1",
"outage": {
"reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"paths": [
"initiator": "3a",
"port_name": "A",
"port_type": "sas",
"wwnn": "5000c2971c1b2b8c",
"wwpn": "5000c2971c1b2b8d"
"pool": "pool0",
"protection_mode": "string",
"rated_life_used_percent": 10,
"rpm": 15000,
"sector_count": 1172123568,
"serial_number": "KHG2VX8R",
"shelf": {
"uid": "7777841915827391056"
"state": "present",
"stats": {
"average_latency": 3,
"iops_total": 12854,
"path_error_count": 0,
"power_on_hours": 21016,
"throughput": 1957888
"type": "ssd",
"uid": "002538E5:71B00B2F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
"usable_size": 959934889984,
"vendor": "NETAPP"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
dr_node
name |
string |
uuid |
string |
drawer
id |
integer |
slot |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
error
The message and code detailing the error state of this disk.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
disk_error_info
reason |
The message and code detailing the error state of this disk. |
type |
string |
Disk error type. |
home_node
_links |
name |
string |
uuid |
string |
key_id
data |
string |
Key ID of the data authentication key |
fips |
string |
Key ID of the FIPS authentication key |
node
_links |
name |
string |
uuid |
string |
error
This error message and code explaining the disk failure.
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
outage
Indicates if a disk has an entry in the failed disk registry, along with the reason for the failure.
boolean |
Indicates whether RAID maintains the state of this disk as failed accross reboots. |
reason |
This error message and code explaining the disk failure. |
disk_path_info
initiator |
string |
Initiator port. |
port_name |
string |
Name of the disk port. |
port_type |
string |
Disk port type. |
wwnn |
string |
Target device's World Wide Node Name. |
wwpn |
string |
Target device's World Wide Port Name. |
shelf
_links |
uid |
string |
stats
average_latency |
integer |
Average I/O latency across all active paths, in milliseconds. |
iops_total |
integer |
Total I/O operations per second read and written to this disk across all active paths. |
path_error_count |
integer |
Disk path error count; failed I/O operations. |
power_on_hours |
integer |
Hours powered on. |
throughput |
integer |
Total disk throughput per second across all active paths, in bytes. |
disk
aggregates |
array[aggregates] |
List of aggregates sharing this disk |
bay |
integer |
Disk shelf bay |
bytes_per_sector |
integer |
Bytes per sector. |
class |
string |
Disk class |
container_type |
string |
Type of overlying disk container |
dr_node |
drawer |
effective_type |
string |
Effective Disk type |
encryption_operation |
string |
This field should only be set as a query parameter in a PATCH operation. It is input only and won't be returned by a subsequent GET. |
error |
array[disk_error_info] |
List of disk errors information. |
fips_certified |
boolean |
firmware_version |
string |
home_node |
key_id |
local |
boolean |
Indicates if a disk is locally attached versus being remotely attached. A locally attached disk resides in the same proximity as the host cluster versus been attached to the remote cluster. |
model |
string |
name |
string |
Cluster-wide disk name |
node |
outage |
Indicates if a disk has an entry in the failed disk registry, along with the reason for the failure. |
paths |
array[disk_path_info] |
List of paths to a disk |
pool |
string |
Pool to which disk is assigned |
protection_mode |
string |
Mode of drive data protection and FIPS compliance. Possible values are:
integer |
Percentage of rated life used |
rpm |
integer |
Revolutions per minute |
sector_count |
integer |
Number of sectors on the disk. |
self_encrypting |
boolean |
serial_number |
string |
shelf |
state |
string |
State |
stats |
type |
string |
Disk interface type |
uid |
string |
The unique identifier for a disk |
usable_size |
integer |
vendor |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
