REST API reference
Retrieves a collection of disks
learn more
  • [doc /storage/disks](#docs-storage-storage_disks)
GET /storage/disks
Introduced In: 9.6
Retrieves a collection of disks.
  • storage disk show
Learn more
rated_life_used_percent
integer
query
False
Filter by rated_life_used_percent
vendor
string
query
False
Filter by vendor
usable_size
integer
query
False
Filter by usable_size
sector_count
integer
query
False
Filter by sector_count
  • Introduced in: 9.9
state
string
query
False
Filter by state
uid
string
query
False
Filter by uid
shelf.uid
string
query
False
Filter by shelf.uid
type
string
query
False
Filter by type
class
string
query
False
Filter by class
local
boolean
query
False
Filter by local
dr_node.uuid
string
query
False
Filter by dr_node.uuid
dr_node.name
string
query
False
Filter by dr_node.name
protection_mode
string
query
False
Filter by protection_mode
  • Introduced in: 9.7
key_id.fips
string
query
False
Filter by key_id.fips
key_id.data
string
query
False
Filter by key_id.data
rpm
integer
query
False
Filter by rpm
paths.initiator
string
query
False
Filter by paths.initiator
paths.port_type
string
query
False
Filter by paths.port_type
paths.wwnn
string
query
False
Filter by paths.wwnn
paths.port_name
string
query
False
Filter by paths.port_name
paths.wwpn
string
query
False
Filter by paths.wwpn
effective_type
string
query
False
Filter by effective_type
model
string
query
False
Filter by model
self_encrypting
boolean
query
False
Filter by self_encrypting
fips_certified
boolean
query
False
Filter by fips_certified
pool
string
query
False
Filter by pool
name
string
query
False
Filter by name
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
firmware_version
string
query
False
Filter by firmware_version
container_type
string
query
False
Filter by container_type
bay
integer
query
False
Filter by bay
serial_number
string
query
False
Filter by serial_number
aggregates.uuid
string
query
False
Filter by aggregates.uuid
aggregates.name
string
query
False
Filter by aggregates.name
stats.throughput
integer
query
False
Filter by stats.throughput
stats.iops_total
integer
query
False
Filter by stats.iops_total
stats.power_on_hours
integer
query
False
Filter by stats.power_on_hours
stats.path_error_count
integer
query
False
Filter by stats.path_error_count
stats.average_latency
integer
query
False
Filter by stats.average_latency
outage.reason.message
string
query
False
Filter by outage.reason.message
outage.reason.code
string
query
False
Filter by outage.reason.code
outage.persistently_failed
boolean
query
False
Filter by outage.persistently_failed
bytes_per_sector
integer
query
False
Filter by bytes_per_sector
home_node.name
string
query
False
Filter by home_node.name
home_node.uuid
string
query
False
Filter by home_node.uuid
drawer.slot
integer
query
False
Filter by drawer.slot
drawer.id
integer
query
False
Filter by drawer.id
error.reason.code
string
query
False
Filter by error.reason.code
error.reason.message
string
query
False
Filter by error.reason.message
error.type
string
query
False
Filter by error.type
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[disk]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "aggregates": [
          "name": "aggr1",
      "bay": "1",
      "bytes_per_sector": "520",
      "class": "solid_state",
      "container_type": "spare",
      "dr_node": {
        "name": "node1",
      "effective_type": "vmdisk",
      "encryption_operation": "string",
      "error": [
          "reason": {
            "code": "string",
            "message": "not responding"
          "type": "notallflashdisk"
      "firmware_version": "NA51",
      "home_node": {
        "name": "node1",
      "key_id": {
        "data": "string",
        "fips": "string"
      "model": "X421_HCOBE450A10",
      "name": "1.0.1",
      "node": {
        "name": "node1",
      "outage": {
        "reason": {
          "code": "721081",
      "paths": [
          "initiator": "3a",
          "port_name": "A",
          "port_type": "sas",
          "wwnn": "5000c2971c1b2b8c",
          "wwpn": "5000c2971c1b2b8d"
      "pool": "pool0",
      "protection_mode": "string",
      "rated_life_used_percent": "10",
      "rpm": "15000",
      "sector_count": "1172123568",
      "serial_number": "KHG2VX8R",
      "shelf": {
        "uid": "7777841915827391056"
      "state": "present",
      "stats": {
        "average_latency": "3",
        "iops_total": "12854",
        "path_error_count": "0",
        "power_on_hours": "21016",
        "throughput": "1957888"
      "type": "ssd",
      "uid": "002538E5:71B00B2F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
      "usable_size": "959934889984",
      "vendor": "NETAPP"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
dr_node
name
string
uuid
string
drawer
id
integer
slot
integer
reason
code
string
Provides an error code.
message
string
Provides an error message detailing the error state of this disk.
disk_error_info
reason
reason
type
string
Disk error type.
home_node
_links
_links
name
string
uuid
string
key_id
data
string
Key ID of the data authentication key
fips
string
Key ID of the FIPS authentication key
node
_links
_links
name
string
uuid
string
reason
code
string
This field provides the error code explaining why a disk failed.
message
string
This field provides the error message explaining why a disk failed.
outage
Indicates if a disk has an entry in the failed disk registry, along with the reason for the failure.
persistently_failed
boolean
Indicates whether RAID maintains the state of this disk as failed accross reboots.
reason
reason
disk_path_info
initiator
string
Initiator port.
port_name
string
Name of the disk port.
port_type
string
Disk port type.
wwnn
string
Target device's World Wide Node Name.
wwpn
string
Target device's World Wide Port Name.
shelf
_links
_links
uid
string
stats
average_latency
integer
Average I/O latency across all active paths, in milliseconds.
iops_total
integer
Total I/O operations per second read and written to this disk across all active paths.
path_error_count
integer
Disk path error count; failed I/O operations.
power_on_hours
integer
Hours powered on.
throughput
integer
Total disk throughput per second across all active paths, in bytes.
disk
aggregates
array[aggregates]
List of aggregates sharing this disk
bay
integer
Disk shelf bay
bytes_per_sector
integer
Bytes per sector.
class
string
Disk class
container_type
string
Type of overlying disk container
dr_node
dr_node
drawer
drawer
effective_type
string
Effective Disk type
string
This field should only be set as a query parameter in a PATCH operation. It is input only and won't be returned by a subsequent GET.
error
array[disk_error_info]
List of disk errors information.
fips_certified
boolean
firmware_version
string
home_node
home_node
key_id
key_id
local
boolean
Indicates if a disk is locally attached versus being remotely attached. A locally attached disk resides in the same proximity as the host cluster versus been attached to the remote cluster.
model
string
name
string
Cluster-wide disk name
node
node
outage
outage
paths
array[disk_path_info]
List of paths to a disk
pool
string
Pool to which disk is assigned
protection_mode
string
Mode of drive data protection and FIPS compliance. Possible values are:
  • open - Disk is unprotected
  • data - Data protection only without FIPS compliance
  • part - Partial protection with FIPS compliance only
  • full - Full data and FIPS compliance protection
integer
Percentage of rated life used
rpm
integer
Revolutions per minute
sector_count
integer
Number of sectors on the disk.
self_encrypting
boolean
serial_number
string
shelf
shelf
state
string
State
stats
stats
type
string
Disk interface type
uid
string
The unique identifier for a disk
usable_size
integer
vendor
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
