REST API reference
Retrieve a collection of disks
GET /storage/disks
Introduced In: 9.6
Retrieves a collection of disks.
  • storage disk show
Learn more
bay
integer
query
False
Filter by bay
sector_count
integer
query
False
Filter by sector_count
  • Introduced in: 9.9
rated_life_used_percent
integer
query
False
Filter by rated_life_used_percent
protection_mode
string
query
False
Filter by protection_mode
  • Introduced in: 9.7
control_standard
string
query
False
Filter by control_standard
  • Introduced in: 9.11
pool
string
query
False
Filter by pool
aggregates.name
string
query
False
Filter by aggregates.name
aggregates.uuid
string
query
False
Filter by aggregates.uuid
outage.reason.arguments.message
string
query
False
Filter by outage.reason.arguments.message
  • Introduced in: 9.10
outage.reason.arguments.code
string
query
False
Filter by outage.reason.arguments.code
outage.reason.code
string
query
False
Filter by outage.reason.code
outage.reason.message
string
query
False
Filter by outage.reason.message
outage.persistently_failed
boolean
query
False
Filter by outage.persistently_failed
state
string
query
False
Filter by state
name
string
query
False
Filter by name
storage_pool.name
string
query
False
Filter by storage_pool.name
storage_pool.uuid
string
query
False
Filter by storage_pool.uuid
vendor
string
query
False
Filter by vendor
shelf.uid
string
query
False
Filter by shelf.uid
right_size_sector_count
integer
query
False
Filter by right_size_sector_count
home_node.name
string
query
False
Filter by home_node.name
home_node.uuid
string
query
False
Filter by home_node.uuid
bytes_per_sector
integer
query
False
Filter by bytes_per_sector
stats.throughput
integer
query
False
Filter by stats.throughput
stats.path_error_count
integer
query
False
Filter by stats.path_error_count
stats.power_on_hours
integer
query
False
Filter by stats.power_on_hours
stats.iops_total
integer
query
False
Filter by stats.iops_total
stats.average_latency
integer
query
False
Filter by stats.average_latency
class
string
query
False
Filter by class
dr_node.name
string
query
False
Filter by dr_node.name
dr_node.uuid
string
query
False
Filter by dr_node.uuid
overall_security
string
query
False
Filter by overall_security
serial_number
string
query
False
Filter by serial_number
error.reason.arguments.message
string
query
False
Filter by error.reason.arguments.message
error.reason.arguments.code
string
query
False
Filter by error.reason.arguments.code
error.reason.code
string
query
False
Filter by error.reason.code
error.reason.message
string
query
False
Filter by error.reason.message
error.type
string
query
False
Filter by error.type
rpm
integer
query
False
Filter by rpm
firmware_version
string
query
False
Filter by firmware_version
self_encrypting
boolean
query
False
Filter by self_encrypting
key_id.fips
string
query
False
Filter by key_id.fips
key_id.data
string
query
False
Filter by key_id.data
container_type
string
query
False
Filter by container_type
usable_size
integer
query
False
Filter by usable_size
physical_size
integer
query
False
Filter by physical_size
model
string
query
False
Filter by model
fips_certified
boolean
query
False
Filter by fips_certified
drawer.id
integer
query
False
Filter by drawer.id
drawer.slot
integer
query
False
Filter by drawer.slot
compliance_standard
string
query
False
Filter by compliance_standard
type
string
query
False
Filter by type
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
location
string
query
False
Filter by location
  • Introduced in: 9.14
effective_type
string
query
False
Filter by effective_type
paths.disk_path_name
string
query
False
Filter by paths.disk_path_name
paths.port_type
string
query
False
Filter by paths.port_type
paths.wwnn
string
query
False
Filter by paths.wwnn
paths.vmdisk_hypervisor_file_name
string
query
False
Filter by paths.vmdisk_hypervisor_file_name
paths.port_name
string
query
False
Filter by paths.port_name
paths.initiator
string
query
False
Filter by paths.initiator
paths.node.name
string
query
False
Filter by paths.node.name
paths.node.uuid
string
query
False
Filter by paths.node.uuid
paths.wwpn
string
query
False
Filter by paths.wwpn
uid
string
query
False
Filter by uid
virtual.storage_account
string
query
False
Filter by virtual.storage_account
virtual.target_address
string
query
False
Filter by virtual.target_address
  • Introduced in: 9.13
virtual.object
string
query
False
Filter by virtual.object
virtual.container
string
query
False
Filter by virtual.container
local
boolean
query
False
Filter by local
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[disk]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "aggregates": [
          "name": "aggr1",
      "bay": 1,
      "bytes_per_sector": 520,
      "class": "solid_state",
      "compliance_standard": "FIPS 140-2",
      "container_type": "spare",
      "control_standard": "TCG Enterprise",
      "dr_node": {
        "name": "node1",
      "effective_type": "vmdisk",
      "encryption_operation": "string",
      "error": [
          "reason": {
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
            "message": "entry doesn't exist"
          "type": "notallflashdisk"
      "firmware_version": "NA51",
      "home_node": {
        "name": "node1",
      "key_id": {
        "data": "string",
        "fips": "string"
      "location": "node-01",
      "model": "X421_HCOBE450A10",
      "name": "1.0.1",
      "node": {
        "name": "node1",
      "outage": {
        "reason": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
      "overall_security": "Level 2",
      "paths": [
          "disk_path_name": "vsim4:3a.10",
          "initiator": "3a",
          "node.name": "vsim4",
          "node.uuid": "cf7fe057-526d-11ec-af4e-0050568e9df0",
          "port_name": "A",
          "port_type": "sas",
          "vmdisk_hypervisor_file_name": "xvds vol0a0567ae156ca59f6",
          "wwnn": "5000c2971c1b2b8c",
          "wwpn": "5000c2971c1b2b8d"
      "physical_size": 228930,
      "pool": "pool0",
      "protection_mode": "data",
      "rated_life_used_percent": 10,
      "right_size_sector_count": 1172123568,
      "rpm": 15000,
      "sector_count": 1172123568,
      "serial_number": "KHG2VX8R",
      "shelf": {
        "uid": "7777841915827391056"
      "state": "present",
      "stats": {
        "average_latency": 3,
        "iops_total": 12854,
        "path_error_count": 0,
        "power_on_hours": 21016,
        "throughput": 1957888
      "storage_pool": {
        "name": "storage_pool_1",
      "type": "ssd",
      "uid": "002538E5:71B00B2F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
      "usable_size": 959934889984,
      "vendor": "NETAPP",
      "virtual": {
        "container": "nviet12122018113936-rg",
        "object": "f1fu63se",
        "storage_account": "nviet12122018113936ps",
        "target_address": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
dr_node
name
string
uuid
string
drawer
id
integer
slot
integer
code
string
Argument code
message
string
Message argument
error
The message and code detailing the error state of this disk.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
disk_error_info
reason
error
type
string
Disk error type.
home_node
_links
_links
name
string
uuid
string
key_id
data
string
Key ID of the data authentication key
fips
string
Key ID of the FIPS authentication key
node
_links
_links
name
string
uuid
string
error
This error message and code explaining the disk failure.
arguments
Message arguments
code
string
Error code
message
string
Error message
outage
Indicates if a disk has an entry in the failed disk registry, along with the reason for the failure.
persistently_failed
boolean
Indicates whether RAID maintains the state of this disk as failed across reboots.
reason
error
disk_path_info
disk_path_name
string
Path-based disk name.
initiator
string
Initiator port.
node.name
string
Controller with the initiator port for this path.
node.uuid
string
Controller UUID, to identify node for this path.
port_name
string
Name of the disk port.
port_type
string
Disk port type.
string
Virtual disk hypervisor file name.
wwnn
string
Target device's World Wide Node Name.
wwpn
string
Target device's World Wide Port Name.
shelf
Shelf
_links
_links
uid
string
stats
average_latency
integer
Average I/O latency across all active paths, in milliseconds.
iops_total
integer
Total I/O operations per second read and written to this disk across all active paths.
path_error_count
integer
Disk path error count; failed I/O operations.
power_on_hours
integer
Hours powered on.
throughput
integer
Total disk throughput per second across all active paths, in bytes.
storage_pool
Shared Storage Pool
_links
_links
name
string
uuid
string
virtual
Information about backing storage for disks on cloud platforms.
container
string
Container name of the virtual disk.
object
string
Object name of the virtual disk.
storage_account
string
Storage account name of the virtual disk.
target_address
string
Target address of the virtual disk.
disk
aggregates
array[aggregates]
List of aggregates sharing this disk
bay
integer
Disk shelf bay
bytes_per_sector
integer
Bytes per sector.
class
string
Disk class
compliance_standard
string
Security standard that the device is certified to.
container_type
string
Type of overlying disk container
control_standard
string
Standard that the device supports for encryption control.
dr_node
dr_node
drawer
drawer
effective_type
string
Effective Disk type
string
This field should only be set as a query parameter in a PATCH operation. It is input only and won't be returned by a subsequent GET.
error
array[disk_error_info]
List of disk errors information.
fips_certified
boolean
firmware_version
string
home_node
home_node
key_id
key_id
local
boolean
Indicates if a disk is locally attached versus being remotely attached. A locally attached disk resides in the same proximity as the host cluster versus been attached to the remote cluster.
location
string
Physical location of the disk
model
string
name
string
Cluster-wide disk name
node
node
outage
outage
overall_security
string
Overall Security rating, for FIPS-certified devices.
paths
array[disk_path_info]
List of paths to a disk
physical_size
integer
Physical size, in units of bytes
pool
string
Pool to which disk is assigned
protection_mode
string
Mode of drive data protection and FIPS compliance. Possible values are:
  • open - Data is unprotected
  • data - Data protection only, without FIPS compliance
  • part - Data is unprotected; other FIPS compliance settings present
  • full - Full data and FIPS compliance protection
  • miss - Protection mode information is not available
integer
Percentage of rated life used
integer
Number of usable disk sectors that remain after subtracting the right-size adjustment for this disk.
rpm
integer
Revolutions per minute
sanitize_spare
boolean
Confirms spare disk sanitization (non-cryptographically).
sector_count
integer
Number of sectors on the disk.
self_encrypting
boolean
serial_number
string
shelf
shelf
Shelf
state
string
State
stats
stats
storage_pool
storage_pool
Shared Storage Pool
type
string
Disk interface type
uid
string
The unique identifier for a disk
usable_size
integer
vendor
string
virtual
virtual
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
