REST API reference
Retrieve the clone split load of a node
Retrieves the clone split load data for a node, which shows the amount of data currently undergoing a split and the remaining capacity for processing. This information helps you manage and monitor the clone split load efficiently.
HTTP method and endpoint
GET /storage/file/clone/split-loads
Introduced in
ONTAP 9.10
Usage notes
Retrieves the clone split load of a node.
  • volume file clone split load show
The GET operation can be used to retrieve information about clone split load data. Split load data is the data currently undergoing the split. There is a limit on split load data. This API communicates how much data is undergoing split and how much can still be processed.<br>
# The API:
/api/storage/file/clone/split-loads
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-loads" -H "accept: application/hal+json"
# The response:
"records": [
    "node": {
      "uuid": "158d592f-a829-11eb-a47b-005056bb46d7",
      "name": "node1",
          "href": "/api/cluster/nodes/158d592f-a829-11eb-a47b-005056bb46d7"
    "load": {
      "maximum": 35184372088832,
      "current": 0,
      "token_reserved": 0,
      "allowable": 35184372088832
        "href": "/api/storage/file/clone/split-loads/158d592f-a829-11eb-a47b-005056bb46d7"
    "node": {
      "uuid": "9686b8d1-a828-11eb-80d8-005056bbe7b6",
      "name": "node2",
          "href": "/api/cluster/nodes/9686b8d1-a828-11eb-80d8-005056bbe7b6"
    "load": {
      "current": 0,
        "href": "/api/storage/file/clone/split-loads/9686b8d1-a828-11eb-80d8-005056bbe7b6"
"num_records": 2,
"_links":
    "href": "/api/storage/file/clone/split-loads"
Learn More
  • [DOC /storage/file/clone]
load.current
integer
query
False
Filter by load.current
load.maximum
integer
query
False
Filter by load.maximum
load.allowable
integer
query
False
Filter by load.allowable
load.token_reserved
integer
query
False
Filter by load.token_reserved
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[split_load]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "load": {
        "allowable": 0,
        "current": 0,
        "token_reserved": 0
      "node": {
        "name": "node1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
load
allowable
integer
Specifies the available file clone split load on the node.
current
integer
Specifies the current on-going file clone split load on the node.
maximum
integer
Specifies the maximum allowable file clone split load on the node at any point in time.
token_reserved
integer
Specifies the file clone split load on the node reserved for tokens.
self
node_reference
_links
_links
name
string
uuid
string
split_load
_links
self_link
load
load
node
node_reference
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
