Retrieve the clone split load of a node
Retrieves the clone split load data for nodes, helping you understand how much data is currently being processed and what remains to be split. This information is useful for managing and optimizing data operations.
HTTP method and endpoint
GET /storage/file/clone/split-loads
Introduced in
ONTAP 9.10
Usage notes
Retrieves the clone split load of a node.
Related Ontap Commands
volume file clone split load show
Retrieving file clone split load related information
The GET operation can be used to retrieve information about clone split load data. Split load data is the data currently undergoing the split. There is a limit on split load data. This API communicates how much data is undergoing split and how much can still be processed.<br>
# The API:
/api/storage/file/clone/split-loads
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/split-loads" -H "accept: application/hal+json"
# The response:
"records": [
"node": {
"uuid": "158d592f-a829-11eb-a47b-005056bb46d7",
"name": "node1",
"href": "/api/cluster/nodes/158d592f-a829-11eb-a47b-005056bb46d7"
"load": {
"maximum": 35184372088832,
"current": 0,
"token_reserved": 0,
"allowable": 35184372088832
"href": "/api/storage/file/clone/split-loads/158d592f-a829-11eb-a47b-005056bb46d7"
"node": {
"uuid": "9686b8d1-a828-11eb-80d8-005056bbe7b6",
"name": "node2",
"href": "/api/cluster/nodes/9686b8d1-a828-11eb-80d8-005056bbe7b6"
"load": {
"current": 0,
"href": "/api/storage/file/clone/split-loads/9686b8d1-a828-11eb-80d8-005056bbe7b6"
"num_records": 2,
"_links":
"href": "/api/storage/file/clone/split-loads"
Learn More
DOC /storage/file/clone]
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
load.maximum |
integer |
query |
False |
Filter by load.maximum |
load.token_reserved |
integer |
query |
False |
Filter by load.token_reserved |
load.allowable |
integer |
query |
False |
Filter by load.allowable |
load.current |
integer |
query |
False |
Filter by load.current |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[split_load] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"load": {
"allowable": 0,
"current": 0,
"token_reserved": 0
"node": {
"name": "node1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
load
allowable |
integer |
Specifies the available file clone split load on the node. |
current |
integer |
Specifies the current on-going file clone split load on the node. |
maximum |
integer |
Specifies the maximum allowable file clone split load on the node at any point in time. |
token_reserved |
integer |
Specifies the file clone split load on the node reserved for tokens. |
_links
self |
node_reference
_links |
name |
string |
uuid |
string |
split_load
_links |
load |
node |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
