REST API reference
Retrieve LUN properties or data
Retrieves logical unit number (LUN) properties or data to access detailed information about a specific LUN. This helps you manage and configure your storage resources effectively.
HTTP method and endpoint
GET /storage/luns/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a LUN.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • attributes.*
  • auto_delete
  • copy.*
  • lun_maps.*
  • movement.*
  • statistics.*
  • vvol.bindings.*
  • metric.*
  • lun bind show
  • lun copy show
  • lun mapping show
  • lun move show
  • lun show
  • volume file clone show-autodelete
Learn more
uuid
string
path
True
The unique identifier of the LUN to retrieve.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
attributes
array[attributes]
An array of name/value pairs optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
Valid in POST except when creating a LUN clone. A cloned can already have attributes from its source. You can add, modify, and delete the attributes of a LUN clone in separate requests after creation of the LUN.
Attributes may be added/modified/removed for an existing LUN using the /api/storage/luns/{lun.uuid}/attributes endpoint. For further information, see DOC /storage/luns/{lun.uuid}/attributes .
There is an added cost to retrieving property values for attributes. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • Introduced in: 9.10
  • readCreate: 1
auto_delete
boolean
This property marks the LUN for auto deletion when the volume containing the LUN runs out of space. This is most commonly set on LUN clones.
When set to true, the LUN becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the LUN is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new LUN is false.
There is an added cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
class
string
The class of LUN.
Optional in POST.
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
consistency_group
consistency_group
The LUN's consistency group. This property is populated for LUNs whose volume is a member of a consistency group. If the volume is a member of a child consistency group, the parent consistency group is reported.
copy
copy
This sub-object applies to LUN copy operations. A LUN can be copied with a POST request that supplies copy.source properties.
Copying a LUN is an asynchronous activity begun by a POST request that specifies the source of the copy in the copy.source properties. The data for the LUN is then asynchronously copied from the source to the destination. The time required to complete the copy depends on the size of the LUN and the load on the cluster. The copy sub-object is populated while a LUN copy is in progress and for two (2) minutes following completion of a copy.
While LUNs are being copied, the status of the LUN copy operations can be obtained using a GET of the source or destination LUN that requests the copy properties. If the LUN is the source LUN for one or more copy operations, the copy.destinations array is populated in GET. If the containing LUN is the destination LUN for a copy operation, the copy.source sub-object is populated in GET. The LUN copy operation can be further modified using a PATCH on the properties on the copy.source sub-object of the copy destination LUN.
There is an added cost to retrieving property values for copy. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
create_time
string
The time the LUN was created.
enabled
boolean
The enabled state of the LUN. LUNs can be disabled to prevent access to the LUN. Certain error conditions also cause the LUN to become disabled. If the LUN is disabled, you can consult the state property to determine if the LUN is administratively disabled (offline) or has become disabled as a result of an error. A LUN in an error condition can be brought online by setting the enabled property to true or brought administratively offline by setting the enabled property to false. Upon creation, a LUN is enabled by default. Valid in PATCH.
location
location
The location of the LUN within the ONTAP cluster. Valid in POST and PATCH.
  • Introduced in: 9.6
lun_maps
array[lun_maps]
The LUN maps with which the LUN is associated.
There is an added cost to retrieving property values for lun_maps. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
metric
metric
Performance numbers, such as IOPS latency and throughput.
movement
movement
This sub-object applies to LUN movement between volumes. A LUN can be moved to a new volume with a PATCH request that changes either the volume portion of property name, location.volume.uuid, or location.volume.name. If the volume is changed using more than one of these properties, the supplied properties used must refer to the same volume.
Moving a LUN between volumes is an asynchronous activity begun by a PATCH request. The data for the LUN is then asynchronously copied from the source volume to the destination volume. The time required to complete the move depends on the size of the LUN and the load on the cluster. The movement sub-object is populated while a LUN movement is in progress and for two (2) minutes following completion of a movement.
While the LUN is being moved, the status of the LUN movement operation can be obtained using a GET for the LUN that requests the movement properties. The LUN movement operation can be further modified using a PATCH on the properties on the movement sub-object.
There is an added cost to retrieving property values for movement. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
name
string
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH.
A PATCH that modifies the qtree and/or base name portion of the LUN path is considered a rename operation.
A PATCH that modifies the volume portion of the LUN path begins an asynchronous LUN movement operation.
os_type
string
The operating system type of the LUN.
Required in POST when creating a LUN that is not a clone of another. Disallowed in POST when creating a LUN clone.
qos_policy
qos_policy
The QoS policy for the LUN. Both traditional and adaptive QoS policies are supported. If both property qos_policy.uuid and qos_policy.name are specified in the same request, they must refer to the same QoS policy. To remove the QoS policy from a LUN, leaving it with no QoS policy, set property qos_policy.name to an empty string ("") in a PATCH request. Valid in POST and PATCH.
Note that a QoS policy can be set on a LUN, or a LUN's volume, but not both.
serial_number
string
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
  • maxLength: 12
  • minLength: 12
  • readOnly: 1
space
space
The storage space related properties of the LUN.
statistics
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
status
status
Status information about the LUN.
svm
svm
The SVM in which the LUN is located.
uuid
string
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
vvol
vvol
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
See POST /protocols/san/vvol-bindings to learn more about creating vVol bindings and DELETE /protocols/san/vvol-bindings to learn more about deleting vVol bindings.
There is an added cost to retrieving property values for vvol. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
      "href": "/api/resourcelink"
  "attributes": [
      "name": "name1",
      "value": "value1"
  "class": "string",
  "comment": "string",
  "consistency_group": {
    "name": "cg1",
    "uuid": "4abc2317-4332-9d37-93a0-20bd29c22df0"
  "copy": {
    "destinations": [
        "max_throughput": 0,
        "name": "/vol/vol1/lun1",
        "progress": {
          "elapsed": 0,
          "failure": {
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
            "target": "uuid"
          "percent_complete": 0,
          "state": "string"
        "uuid": "1bc327d5-4654-5284-a116-f182282240b4"
    "source": {
      "name": "/vol/vol2/lun1",
      "progress": {
        "elapsed": 0,
        "failure": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "target": "uuid"
        "state": "string"
      "uuid": "03c05019-40d9-3945-c767-dca4c3be5e90"
  "create_time": "2018-06-04T19:00:00Z",
  "location": {
    "logical_unit": "lun1",
    "node": {
      "name": "node1",
    "qtree": {
      "id": 1,
      "name": "qt1"
    "volume": {
      "name": "volume1",
  "lun_maps": [
      "igroup": {
        "name": "igroup1",
      "logical_unit_number": 0
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25T11:20:13Z"
  "movement": {
    "paths": {
      "destination": "/vol/vol1/lun1",
      "source": "/vol/vol2/lun2"
    "progress": {
      "elapsed": 0,
      "failure": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
        "target": "uuid"
      "state": "string"
  "name": "/vol/volume1/qtree1/lun1",
  "os_type": "string",
  "qos_policy": {
    "name": "qos1",
  "serial_number": "string",
  "space": {
    "size": 1073741824,
    "used": 0
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "status": {
    "container_state": "string",
    "state": "online"
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vvol": {
    "bindings": [
        "id": 1,
        "partner": {
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN was not found.
5374876
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
attributes
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Optional in POST.
_links
_links
name
string
The attribute name.
value
string
The attribute value.
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
Persistent reservations for the patched LUN are also preserved.
consistency_group
_links
_links
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
code
string
Argument code
message
string
Message argument
error
Error information provided if the asynchronous LUN copy operation fails.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
progress
Properties related to the progress of an active or recently completed LUN copy.
elapsed
integer
The amount of time that has elapsed since the start of the LUN copy, in seconds.
failure
error
percent_complete
integer
The percentage completed of the LUN copy.
state
string
The state of the LUN copy.
volume_snapshot_blocked
boolean
This property reports if volume Snapshot copies are blocked by the LUN copy. This property can be polled to identify when volume Snapshot copies can be resumed after beginning a LUN copy.
destinations
A LUN copy operation in which the containing LUN is the source of the copy.
_links
_links
max_throughput
integer
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN copy. See property copy.source.max_throughput for further details.
name
string
The fully qualified path of the LUN copy destination composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN.
progress
progress
uuid
string
The unique identifier of the LUN copy destination.
progress
elapsed
integer
failure
error
percent_complete
integer
state
string
Valid in PATCH when an LUN copy is active. Set to paused to pause a LUN copy. Set to replicating to resume a paused LUN copy.
boolean
source
The source LUN of a LUN copy operation in which the containing LUN is the destination of the copy.
Valid in POST except when creating a LUN clone. A LUN copy request cannot be combined with setting any other LUN properties except the destination location. All other properties of the destination LUN come from the source LUN.
_links
_links
max_throughput
integer
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN copy. This property can be used to throttle a transfer and limit its impact on the performance of the source and destination nodes. The specified value will be rounded up to the nearest megabyte.
If this property is not specified in a POST that begins a LUN copy, throttling is not applied to the data transfer.
For more information, see Size properties in the docs section of the ONTAP REST API documentation.
Valid only in a POST that begins a LUN copy or a PATCH when a LUN copy is already in process.
  • format: int64
name
string
The fully qualified path of the LUN copy source composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN.
Set this property in POST to specify the source for a LUN copy operation.
progress
progress
uuid
string
The unique identifier of the LUN copy source.
copy
destinations
array[destinations]
An array of destination LUNs of LUN copy operations in which the containing LUN is the source of the copy.
source
source
node
The cluster node that hosts the LUN.
_links
_links
name
string
uuid
string
qtree
The qtree in which the LUN is optionally located. Valid in POST and PATCH.
If properties name and location.qtree.name and/or location.qtree.uuid are specified in the same request, they must refer to the same qtree.
A PATCH that modifies the qtree of the LUN is considered a rename operation.
_links
_links
id
integer
The identifier for the qtree, unique within the qtree's volume.
name
string
The name of the qtree.
volume
The volume in which the LUN is located. Valid in POST and PATCH.
If properties name and location.volume.name and/or location.volume.uuid are specified in the same request, they must refer to the same volume.
A PATCH that modifies the volume of the LUN begins an asynchronous LUN movement operation.
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
location
logical_unit
string
The base name component of the LUN. Valid in POST and PATCH.
If properties name and location.logical_unit are specified in the same request, they must refer to the base name.
A PATCH that modifies the base name of the LUN is considered a rename operation.
node
node
qtree
qtree
volume
volume
igroup
The initiator group to which the LUN is mapped.
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
lun_maps
A LUN map with which the LUN is associated.
_links
_links
igroup
igroup
logical_unit_number
integer
The logical unit number assigned to the LUN for initiators in the initiator group.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
paths
The fully qualified LUN path names involved in the LUN movement.
destination
string
The fully qualified path of the LUN movement destination composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN.
source
string
The fully qualified path of the LUN movement source composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN.
error
Error information provided if the asynchronous LUN movement operation fails.
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
progress
Properties related to the progress of an active or recently completed LUN movement.
elapsed
integer
The amount of time that has elapsed since the start of the LUN movement, in seconds.
failure
error
percent_complete
integer
The percentage completed of the LUN movement.
state
string
The state of the LUN movement.
Valid in PATCH when an LUN movement is active. Set to paused to pause a LUN movement. Set to replicating to resume a paused LUN movement.
boolean
This property reports if volume Snapshot copies are blocked by the LUN movement. This property can be polled to identify when volume Snapshot copies can be resumed after beginning a LUN movement.
movement
max_throughput
integer
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN movement. This property can be used to throttle a transfer and limit its impact on the performance of the source and destination nodes. The specified value will be rounded up to the nearest megabyte.
If this property is not specified in a POST that begins a LUN movement, throttling is not applied to the data transfer.
This property is valid only in a POST that begins a LUN movement or a PATCH when a LUN movement is already in process.
  • format: int64
paths
paths
progress
progress
qos_policy
_links
_links
name
string
The name of the QoS policy. To remove the QoS policy from a LUN, leaving it with no QoS policy, set this property to an empty string ("") in a PATCH request. Valid in POST and PATCH.
uuid
string
The unique identifier of the QoS policy. Valid in POST and PATCH.
guarantee
Properties that request and report the space guarantee for the LUN.
requested
boolean
The requested space reservation policy for the LUN. If true, a space reservation is requested for the LUN; if false, the LUN is thin provisioned. Guaranteeing a space reservation request for a LUN requires that the volume in which the LUN resides is also space reserved and that the fractional reserve for the volume is 100%. Valid in POST and PATCH.
reserved
boolean
Reports if the LUN is space guaranteed.
If true, a space guarantee is requested and the containing volume and aggregate support the request. If false, a space guarantee is not requested or a space guarantee is requested and either the containing volume or aggregate do not support the request.
space
guarantee
guarantee
boolean
To leverage the benefits of SCSI thin provisioning, it must be supported by your host. SCSI thin provisioning uses the Logical Block Provisioning feature as defined in the SCSI SBC-3 standard. Only hosts that support this standard can use SCSI thin provisioning in ONTAP.
When you enable SCSI thin provisioning support in ONTAP, you turn on the following SCSI thin provisioning features:
  • Unmapping and reporting space usage for space reclamation
  • Reporting resource exhaustion errors
The value of this property is not propagated to the destination when a LUN is cloned as a new LUN or copied; it is reset to false. The value of this property is maintained from the destination LUN when a LUN is overwritten as a clone.
  • Default value: 1
size
integer
The total provisioned size of the LUN. The LUN size can be increased but not be made smaller using the REST interface.
The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes in bytes. The actual minimum and maxiumum sizes vary depending on the ONTAP version, ONTAP platform and the available space in the containing volume and aggregate.
  • example: 1073741824
  • format: int64
  • Max value: 140737488355328
  • Min value: 4096
used
integer
The amount of space consumed by the main data stream of the LUN.
This value is the total space consumed in the volume by the LUN, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways SAN filesystems and applications utilize blocks within a LUN, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the LUN blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
status
container_state
string
The state of the volume and aggregate that contain the LUN. LUNs are only available when their containers are available.
mapped
boolean
Reports if the LUN is mapped to one or more initiator groups.
read_only
boolean
Reports if the LUN allows only read access.
state
string
The state of the LUN. Normal states for a LUN are online and offline. Other states indicate errors.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
partner
The LUN partner that this LUN is bound to. If this LUN is a vvol class LUN, the partner is a protocol_endpoint class LUN.
_links
_links
name
string
The name of the partner LUN.
uuid
string
The unique identifier of the partner LUN.
bindings
A vVol binding with which the LUN is associated.
_links
_links
id
integer
The identifier assigned to the binding. The bind identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
partner
partner
vvol
bindings
array[bindings]
Bindings between the LUN, which must be of class protocol_endpoint or vvol, and LUNs of the opposite class.
A class vvol LUN must be bound to a class protocol_endpoint LUN in order to be accessed. Class protocol_endpoint and vvol LUNs allow many-to-many bindings. A LUN of one class is allowed to be bound to zero or more LUNs of the opposite class. The binding between any two specific LUNs is reference counted. When a binding is created that already exists, the binding count is incremented. When a binding is deleted, the binding count is decremented, but the LUNs remain bound if the resultant reference count is greater than zero. When the binding count reaches zero, the binding is destroyed.
The bindings array contains LUNs of the opposite class of the containing LUN object.
There is an added cost to retrieving property values for vvol.bindings. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
is_bound
boolean
Reports if the LUN is part of a VMware virtual volume (vVol) bind relationship. This is true if the LUN is of class protocol_endpoint or vvol and has one or more bindings to a LUN of the opposite class. This is false if the LUN is of class regular or unbound.
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
