Create a vVol binding
Creates a vVol binding to establish a reference between specific LUNs, which is useful when managing virtual volumes in ONTAP. This process increments the binding count if the specified binding already exists.
HTTP method and endpoint
POST /protocols/san/vvol-bindings
Introduced in
ONTAP 9.10
Usage notes
The binding between any two specific LUNs is reference counted. When a binding is created that already exists, the binding count is incremented.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the vVol binding. -
protocol_endpoint.uuidorprotocol_endpoint.name- Existing classprotocol_endpointLUN to bind to the specified classvvolLUN. -
vvol.uuidorvvol.name- Existing classvvolLUN to bind to the specified classprotocol_endpointLUN.
Related ONTAP commands
lun bind create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
count |
integer |
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter |
id |
integer |
The identifier assigned to the vVol binding. The bind identifier is unique amongst all class |
is_optimal |
boolean |
Indicates if the class |
protocol_endpoint |
The class |
svm |
The SVM in which the vVol binding and its LUNs are located. Required in POST. |
vvol |
The class |
Example request
"count": 1,
"id": 1,
"is_optimal": 1,
"protocol_endpoint": {
"name": "/vol/volume1/lun1",
"svm": {
"name": "svm1",
"vvol": {
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[vvol_binding] |
"records": [
"count": 1,
"id": 1,
"is_optimal": 1,
"svm": {
"name": "svm1",
"vvol": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
The specified SVM does not exist or is not accessible to the caller. |
2621706 |
Both the SVM UUID and SVM name were supplied, but don't refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5374238 |
A LUN in a Snapshot copy was specified. |
5374323 |
The LUN specified as the protocol endpoint LUN is not of class |
5374325 |
The LUN specified as the vVol LUN is not of class |
5374874 |
The UUID and name supplied for the protocol endpoint of Vvol LUN do not refer to the same LUN. Use to the |
5374875 |
The protocol endpoint or vVol LUN was not found or is not accessible to the caller. Use to the |
5374876 |
The protocol endpoint or vVol LUN was not found in the SVM. Use to the |
5374924 |
No protocol endpoint LUN was supplied. |
5374925 |
No vVol LUN was supplied. |
href |
string |
_links
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
name |
string |
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH. |
uuid |
string |
The unique identifier of the LUN. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
vvol
The class vvol LUN in the vVol binding. Required in POST.
name |
string |
uuid |
string |
vvol_binding
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
count |
integer |
id |
integer |
is_optimal |
boolean |
protocol_endpoint |
The class |
svm |
vvol |
The class |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
