REST API reference
Create a vVol binding
Creates a vVol binding to establish a reference-counted link between two specific LUNs. Use this endpoint when you need to increment the binding count for an existing connection or set up a new binding between a protocol endpoint and a vVol LUN within an SVM.
HTTP method and endpoint
POST /protocols/san/vvol-bindings
Introduced in
ONTAP 9.10
Usage notes
The binding between any two specific LUNs is reference counted. When a binding is created that already exists, the binding count is incremented.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the vVol binding.
  • protocol_endpoint.uuid or protocol_endpoint.name - Existing class protocol_endpoint LUN to bind to the specified class vvol LUN.
  • vvol.uuid or vvol.name - Existing class vvol LUN to bind to the specified class protocol_endpoint LUN.
  • lun bind create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
count
integer
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
id
integer
The identifier assigned to the vVol binding. The bind identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
is_optimal
boolean
Indicates if the class procotol_endpoint LUN and the class vvol LUN are on the same cluster node.
protocol_endpoint
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
svm
svm
The SVM in which the vVol binding and its LUNs are located. Required in POST.
vvol
vvol
The class vvol LUN in the vVol binding. Required in POST.
Example request
  "count": 1,
  "id": 1,
  "is_optimal": 1,
  "protocol_endpoint": {
    "name": "/vol/volume1/lun1",
  "svm": {
    "name": "svm1",
  "vvol": {
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[vvol_binding]
  "num_records": 1,
  "records": [
      "count": 1,
      "id": 1,
      "is_optimal": 1,
      "svm": {
        "name": "svm1",
      "vvol": {
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The specified SVM does not exist or is not accessible to the caller.
2621706
Both the SVM UUID and SVM name were supplied, but don't refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5374238
A LUN in a Snapshot copy was specified.
5374323
The LUN specified as the protocol endpoint LUN is not of class protocol_endpoint.
5374325
The LUN specified as the vVol LUN is not of class vvol.
5374874
The UUID and name supplied for the protocol endpoint of Vvol LUN do not refer to the same LUN. Use to the target property of the error object to differentiate between the protocol endpoint LUN and the vVol LUN.
5374875
The protocol endpoint or vVol LUN was not found or is not accessible to the caller. Use to the target property of the error object to differentiate between the protocol endpoint LUN and the vVol LUN.
5374876
The protocol endpoint or vVol LUN was not found in the SVM. Use to the target property of the error object to differentiate between the protocol endpoint LUN and the vVol LUN.
5374924
No protocol endpoint LUN was supplied.
5374925
No vVol LUN was supplied.
string
protocol_endpoint
name
string
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH.
uuid
string
The unique identifier of the LUN.
svm
name
string
The name of the SVM.
uuid
string
vvol
name
string
uuid
string
vvol_binding
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
count
integer
id
integer
is_optimal
boolean
protocol_endpoint
protocol_endpoint
svm
svm
vvol
vvol
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
