REST API reference
Retrieve an NVMe namespace
Retrieves an NVMe namespace to access its configuration and status information. This helps you manage and monitor NVMe storage resources effectively.
HTTP method and endpoint
GET /storage/namespaces/{uuid}
Introduced in
ONTAP 9.6
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • auto_delete
  • subsystem_map.*
  • status.mapped
  • statistics.*
  • metric.*
  • vserver nvme namespace show
  • vserver nvme subsystem map show
uuid
string
path
True
The unique identifier of the NVMe namespace to retrieve.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
auto_delete
boolean
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones.
When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new NVMe namespace is false.
There is an added cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
create_time
string
The time the NVMe namespace was created.
enabled
boolean
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, you can check the state property to determine what error disabled the namespace. An NVMe namespace is enabled automatically when it is created.
location
location
The location of the NVMe namespace within the ONTAP cluster. Valid in POST.
NVMe namespaces do not support rename, or movement between volumes.
  • Introduced in: 9.6
  • readCreate: 1
metric
metric
Performance numbers, such as IOPS latency and throughput
name
string
The fully qualified path name of the NVMe namespace composed of a "/vol" prefix, the volume name, the (optional) qtree name and base name of the namespace. Valid in POST.
os_type
string
The operating system type of the NVMe namespace.
Required in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone.
space
space
The storage space related properties of the NVMe namespace.
statistics
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
status
status
Status information about the NVMe namespace.
subsystem_map
subsystem_map
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems.
There is an added cost to retrieving property values for subsystem_map. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
svm
svm
uuid
string
The unique identifier of the NVMe namespace.
      "href": "/api/resourcelink"
  "comment": "string",
  "create_time": "2018-06-04T19:00:00Z",
  "location": {
    "namespace": "namespace1",
    "node": {
      "name": "node1",
    "qtree": {
      "id": 1,
      "name": "qt1"
    "volume": {
      "name": "volume1",
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25T11:20:13Z"
  "name": "/vol/volume1/qtree1/namespace1",
  "os_type": "string",
  "space": {
    "block_size": "512",
    "size": 1073741824,
    "used": 0
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "status": {
    "container_state": "string",
    "state": "online"
  "subsystem_map": {
    "anagrpid": "00103050h",
    "nsid": "00000001h",
    "subsystem": {
      "name": "string",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
72090006
The specified namespace was not found.
72090007
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
source
The source NVMe namespace for a namespace clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same namespace.
Valid in POST to create a new NVMe namespace as a clone of the source.
Valid in PATCH to overwrite an existing NVMe namespace's data as a clone of another.
clone
This sub-object is used in POST to create a new NVMe namespace as a clone of an existing namespace, or PATCH to overwrite an existing namespace as a clone of another. Setting a property in this sub-object indicates that a namespace clone is desired.
When used in a PATCH, the patched NVMe namespace's data is over-written as a clone of the source and the following properties are preserved from the patched namespace unless otherwise specified as part of the PATCH: auto_delete (unless specified in the request), subsystem_map, status.state, and uuid.
node
The cluster node that hosts the NVMe namespace.
_links
_links
name
string
uuid
string
qtree
The qtree in which the NVMe namespace is optionally located. Valid in POST.
If properties name and location.qtree.name and/or location.qtree.uuid are specified in the same request, they must refer to the same qtree.
NVMe namespaces do not support rename.
_links
_links
id
integer
The identifier for the qtree, unique within the qtree's volume.
name
string
The name of the qtree.
volume
The volume in which the NVMe namespace is located. Valid in POST.
If properties name and location.volume.name and/or location.volume.uuid are specified in the same request, they must refer to the same volume.
NVMe namespaces do not support movement between volumes.
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
location
namespace
string
The base name component of the NVMe namespace. Valid in POST.
If properties name and location.namespace are specified in the same request, they must refer to the base name.
node
node
qtree
qtree
volume
volume
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
guarantee
Properties that request and report the space guarantee for the NVMe namespace.
requested
boolean
The requested space reservation policy for the NVMe namespace. If true, a space reservation is requested for the namespace; if false, the namespace is thin provisioned. Guaranteeing a space reservation request for a namespace requires that the volume in which the namespace resides also be space reserved and that the fractional reserve for the volume be 100%.
The space reservation policy for an NVMe namespace is determined by ONTAP.
  • readOnly: 1
reserved
boolean
Reports if the NVMe namespace is space guaranteed.
This property is true if a space guarantee is requested and the containing volume and aggregate support the request. This property is false if a space guarantee is not requested or if a space guarantee is requested and either the containing volume and aggregate do not support the request.
space
block_size
integer
The size of blocks in the namespace in bytes.
Valid in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone. Valid in POST.
guarantee
guarantee
size
integer
The total provisioned size of the NVMe namespace. Valid in POST and PATCH. The NVMe namespace size can be increased but not be made smaller using the REST interface.
The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes in bytes. The maximum size is variable with respect to large NVMe namespace support in ONTAP. If large namespaces are supported, the maximum size is 128 TB (140737488355328 bytes) and if not supported, the maximum size is just under 16 TB (17557557870592 bytes). The minimum size supported is always 4096 bytes.
For more information, see Size properties in the docs section of the ONTAP REST API documentation.
  • example: 1073741824
  • format: int64
  • Max value: 140737488355328
  • Min value: 4096
used
integer
The amount of space consumed by the main data stream of the NVMe namespace.
This value is the total space consumed in the volume by the NVMe namespace, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways NVMe filesystems and applications utilize blocks within a namespace, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the namespace blocks are utilized outside of ONTAP, this property should not be used and an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
status
container_state
string
The state of the volume and aggregate that contain the NVMe namespace. Namespaces are only available when their containers are available.
mapped
boolean
Reports if the NVMe namespace is mapped to an NVMe subsystem.
read_only
boolean
Reports if the NVMe namespace allows only read access.
state
string
The state of the NVMe namespace. Normal states for a namespace are online and offline. Other states indicate errors.
subsystem
The NVMe subsystem to which the NVMe namespace is mapped.
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
The unique identifier of the NVMe subsystem.
subsystem_map
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
subsystem
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
