REST API reference
Retrieve an NVMe namespace
GET /storage/namespaces/{uuid}
Introduced In: 9.6
Retrieves an NVMe namespace.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • auto_delete
  • space.physical_used
  • space.physical_used_by_snapshots
  • space.efficiency_ratio
  • subsystem_map.*
  • status.mapped
  • statistics.*
  • metric.*
  • vserver nvme namespace show
  • vserver nvme subsystem map show
uuid
string
path
True
The unique identifier of the NVMe namespace to retrieve.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
auto_delete
boolean
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones.
When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new NVMe namespace is false.
There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
consistency_group
consistency_group
The namespace's consistency group. This property is populated for namespaces that are members of a consistency group. If the namespace is a member of a child consistency group, the parent consistency group is reported. A namespace's consistency group is the consistency group of its containing volume.
create_time
string
The time the NVMe namespace was created.
enabled
boolean
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, check the status.state property to determine what error disabled the namespace. An NVMe namespace is enabled automatically when it is created.
location
location
The location of the NVMe namespace within the ONTAP cluster. NVMe namespaces do not support rename, or movement between volumes. Valid in POST.
  • Introduced in: 9.6
  • readCreate: 1
metric
metric
Performance numbers, such as IOPS latency and throughput
name
string
The name of the NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
Renaming an NVMe namespace is not supported. Valid in POST.
os_type
string
The operating system type of the NVMe namespace.
Required in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone.
space
space
The storage space related properties of the NVMe namespace.
statistics
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
status
status
Status information about the NVMe namespace.
subsystem_map
subsystem_map
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems.
There is an added computational cost to retrieving property values for subsystem_map. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more. These properties are supported only for GET.
svm
svm
uuid
string
The unique identifier of the NVMe namespace.
      "href": "/api/resourcelink"
  "comment": "string",
  "consistency_group": {
    "name": "cg1",
    "uuid": "4abc2317-4332-9d37-93a0-20bd29c22df0"
  "create_time": "2018-06-04 15:00:00 -0400",
  "location": {
    "namespace": "namespace1",
    "node": {
      "name": "node1",
    "qtree": {
      "id": 1,
      "name": "qt1"
    "volume": {
      "name": "volume1",
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25 06:20:13 -0500"
  "name": "/vol/volume1/qtree1/namespace1",
  "os_type": "string",
  "space": {
    "block_size": 512,
    "efficiency_ratio": 2.5,
    "physical_used": 1073741824,
    "physical_used_by_snapshots": 1073741824,
    "size": 1073741824,
    "used": 0
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "status": {
    "container_state": "string",
    "state": "online"
  "subsystem_map": {
    "anagrpid": "00103050h",
    "nsid": "00000001h",
    "subsystem": {
      "hosts": [
          "dh_hmac_chap": {
            "group_size": "string",
            "hash_function": "string",
            "mode": "bidirectional"
          "nqn": "nqn.1992-01.example.com:string",
          "priority": "string",
          "proximity": {
            "peer_svms": [
                "name": "peer1",
                "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
          "tls": {
            "key_type": "configured"
      "name": "subsystem1",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
72090006
The specified namespace was not found.
72090007
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
source
The source NVMe namespace for a namespace clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same namespace.
Valid in POST to create a new NVMe namespace as a clone of the source.
Valid in PATCH to overwrite an existing NVMe namespace's data as a clone of another.
clone
This sub-object is used in POST to create a new NVMe namespace as a clone of an existing namespace, or PATCH to overwrite an existing namespace as a clone of another. Setting a property in this sub-object indicates that a namespace clone is desired.
When used in a PATCH, the patched NVMe namespace's data is over-written as a clone of the source and the following properties are preserved from the patched namespace unless otherwise specified as part of the PATCH: auto_delete (unless specified in the request), subsystem_map, status.state, and uuid.
consistency_group
_links
_links
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
lun
The source LUN for convert operation. This can be specified using property convert.lun.uuid or convert.lun.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST. A convert request from LUN to NVMe namespace cannot be combined with setting any other namespace properties. All other properties of the converted NVMe namespace come from the source LUN.
convert
This sub-object is used in POST to convert a valid in-place LUN to an NVMe namespace. Setting a property in this sub-object indicates that a conversion from the specified LUN to NVMe namespace is desired.
node
The cluster node that hosts the NVMe namespace.
_links
_links
name
string
uuid
string
qtree
The qtree in which the NVMe namespace is optionally located. Valid in POST.
If properties name and location.qtree.name and/or location.qtree.uuid are specified in the same request, they must refer to the same qtree.
NVMe namespaces do not support rename.
_links
_links
id
integer
The identifier for the qtree, unique within the qtree's volume.
name
string
The name of the qtree.
volume
The volume in which the NVMe namespace is located. Valid in POST.
If properties name and location.volume.name and/or location.volume.uuid are specified in the same request, they must refer to the same volume.
NVMe namespaces do not support movement between volumes.
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • x-nullable: true
location
namespace
string
The base name component of the NVMe namespace. Valid in POST.
If properties name and location.namespace are specified in the same request, they must refer to the base name.
node
node
qtree
qtree
volume
volume
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
self
qos_policy
The QoS policy for the volume provisioned to host the namespace. This property is only supported when the request provisions a new volume. If no qos_policy is provided, a policy is be set based on the storage_service.name, which defaults to the most performant service available.
_links
self_link
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
snapshot_policy_reference
This is a reference to the snapshot policy.
_links
_links
name
string
uuid
string
storage_service
Determines the placement of the namespace based on the value specified. Valid in POST.
name
string
Storage service name. If not specified, the default value is the most performant for the platform.
object_stores
tiering
The tiering placement and policy definitions for the volume provisioned to host the namespace. This property is only supported when the request provisions a new volume.
object_stores
array[object_stores]
Object stores to use. Used for placement.
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold.
FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH.
all ‐ Allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks.
auto ‐ Allows tiering of both snapshot and active file system user data to the cloud store
none ‐ Volume blocks are not be tiered to the cloud store.
snapshot_only ‐ Allows tiering of only the volume snapshots not associated with the active file system.
The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy it is 31 days.
provisioning_options
Options that are applied to the operation.
guarantee
Properties that request and report the space guarantee for the NVMe namespace.
requested
boolean
The requested space reservation policy for the NVMe namespace. If true, a space reservation is requested for the namespace; if false, the namespace is thin provisioned. Guaranteeing a space reservation request for a namespace requires that the volume in which the namespace resides also be space reserved and that the fractional reserve for the volume be 100%.
The space reservation policy for an NVMe namespace is determined by ONTAP.
  • readOnly: 1
  • x-nullable: true
reserved
boolean
Reports if the NVMe namespace is space guaranteed.
This property is true if a space guarantee is requested and the containing volume and aggregate support the request. This property is false if a space guarantee is not requested or if a space guarantee is requested and either the containing volume and aggregate do not support the request.
space
block_size
integer
The size of blocks in the namespace in bytes. The default for namespaces with an os_type of vmware is 512. All other namespaces default to 4096.
Valid in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone. Valid in POST.
efficiency_ratio
number
The storage efficiency ratio of the namespace without snapshots. (Logical Used / Used) This property is not available on the namespace object in the REST API and is not reported for GET requests. See the containing volume object for this information.
guarantee
guarantee
physical_used
integer
The number of bytes consumed on the disk by the namespace, excluding snapshots. This property is not available on the namespace object in the REST API and is not reported for GET requests. See the containing volume object for this information.
integer
The number of bytes consumed on the disk by the namespace's snapshots. This property is not available on the namespace object in the REST API and is not reported for GET requests. See the containing volume object for this information.
size
integer
The total provisioned size of the NVMe namespace. Valid in POST and PATCH. The NVMe namespace size can be increased but not be made smaller using the REST interface.
The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes in bytes. The maximum size is variable with respect to large NVMe namespace support in ONTAP. If large namespaces are supported, the maximum size is 128 TB (140737488355328 bytes) and if not supported, the maximum size is just under 16 TB (17557557870592 bytes). The minimum size supported is always 4096 bytes.
For more information, see Size properties in the docs section of the ONTAP REST API documentation.
  • example: 1073741824
  • format: int64
  • Max value: 140737488355328
  • Min value: 4096
  • x-nullable: true
used
integer
The amount of space consumed by the main data stream of the NVMe namespace.
This value is the total space consumed in the volume by the NVMe namespace, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways NVMe filesystems and applications utilize blocks within a namespace, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the namespace blocks are utilized outside of ONTAP, this property should not be used and an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
  • x-nullable: true
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
status
container_state
string
The state of the volume and aggregate that contain the NVMe namespace. Namespaces are only available when their containers are available.
mapped
boolean
Reports if the NVMe namespace is mapped to an NVMe subsystem.
read_only
boolean
Reports if the NVMe namespace allows only read access.
state
string
The state of the NVMe namespace. Normal states for a namespace are online and offline. Other states indicate errors.
consistency_group_nvme_host_dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
peer_svms
A reference to an SVM peer relationship.
_links
_links
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
Properties that define the SVMs to which the host is proximal. This information is used to properly report active optimized and active non-optimized network paths using an NVMe controller. If no configuration has been specified for the host, the sub-object is not present in GET requests.
These properties apply to all instances of the host in the NVMe subsystem in the SVM and its peers.
local_svm
boolean
A boolean that indicates if the host is proximal to the SVM for which it is configured.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the host is proximal.
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
key_type
string
The method by which the TLS pre-shared key (PSK) is configured for the host. Optional in POST.
The values for property key_type and property configured_psk must logically agree.
Possible values:
  • none - TLS is not configured for the host connection. No value is allowed for property configured_psk.
  • configured - A user supplied PSK is configured for the NVMe/TCP-TLS transport connection between the host and the NVMe subsystem. A valid value for property configured_psk is required.
This property defaults to none unless a value is supplied for configured_psk in which case it defaults to configured.
hosts
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
dh_hmac_chap
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target.
priority
string
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used.
proximity
proximity
tls
tls
subsystem
The NVMe subsystem to which the NVMe namespace is mapped.
_links
_links
comment
string
A configurable comment for the NVMe subsystem. Optional in POST.
hosts
array[hosts]
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST.
name
string
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Optional in POST.
os_type
string
The host operating system of the NVMe subsystem's hosts. Optional in POST.
uuid
string
The unique identifier of the NVMe subsystem.
subsystem_map
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
subsystem
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
