REST API reference
Retrieve storage ports
Retrieves a collection of storage ports to view their configuration and status within your ONTAP environment.
HTTP method and endpoint
GET /storage/ports
Introduced in
ONTAP 9.6
  • storage port show
Learn more
cable.length
string
query
False
Filter by cable.length
cable.identifier
string
query
False
Filter by cable.identifier
cable.serial_number
string
query
False
Filter by cable.serial_number
cable.part_number
string
query
False
Filter by cable.part_number
description
string
query
False
Filter by description
speed
number
query
False
Filter by speed
state
string
query
False
Filter by state
board_name
string
query
False
Filter by board_name
type
string
query
False
Filter by type
  • Introduced in: 9.9
part_number
string
query
False
Filter by part_number
mode
string
query
False
Filter by mode
  • Introduced in: 9.8
mac_address
string
query
False
Filter by mac_address
serial_number
string
query
False
Filter by serial_number
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
firmware_version
string
query
False
Filter by firmware_version
redundant
boolean
query
False
Filter by redundant
in_use
boolean
query
False
Filter by in_use
wwn
string
query
False
Filter by wwn
error.message
string
query
False
Filter by error.message
error.corrective_action
string
query
False
Filter by error.corrective_action
enabled
boolean
query
False
Filter by enabled
name
string
query
False
Filter by name
wwpn
string
query
False
Filter by wwpn
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[storage_port]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "board_name": "string",
      "cable": {
        "identifier": "500a0980000b6c3f-50000d1703544b80",
        "length": "2m",
        "part_number": "112-00431+A0",
        "serial_number": "616930439"
      "description": "SAS Host Adapter 2a (PMC-Sierra PM8072 rev. C)",
      "error": {
        "corrective_action": "string",
        "message": "string"
      "firmware_version": "03.08.09.00",
      "mac_address": "string",
      "mode": "storage",
      "name": "2a",
      "node": {
        "name": "node1",
      "part_number": "111-03801",
      "serial_number": "7A2463CC45B",
      "speed": "6",
      "state": "online",
      "type": "sas",
      "wwn": "50000d1703544b80",
      "wwpn": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
cable
identifier
string
length
string
part_number
string
serial_number
string
error
corrective_action
string
Error corrective action
message
string
Error message
self
node
_links
_links
name
string
uuid
string
storage_port
board_name
string
cable
cable
description
string
enabled
boolean
error
error
firmware_version
string
in_use
boolean
Specifies whether any devices are connected through this port
mac_address
string
mode
string
Operational mode of a non-dedicated Ethernet port
name
string
node
node
part_number
string
redundant
boolean
Specifies whether all devices connected through this port have a redundant path from another port
serial_number
string
speed
number
Operational port speed in Gbps
state
string
type
string
wwn
string
World Wide Name
wwpn
string
World Wide Port Name
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
