Retrieve storage ports
Retrieves a collection of storage ports, helping you understand the available port configurations in your environment.
HTTP method and endpoint
GET /storage/ports
Introduced in
ONTAP 9.6
Related ONTAP commands
storage port show
Learn more
mac_address |
string |
query |
False |
Filter by mac_address |
part_number |
string |
query |
False |
Filter by part_number |
enabled |
boolean |
query |
False |
Filter by enabled
redundant |
boolean |
query |
False |
Filter by redundant
in_use |
boolean |
query |
False |
Filter by in_use
state |
string |
query |
False |
Filter by state |
firmware_version |
string |
query |
False |
Filter by firmware_version
description |
string |
query |
False |
Filter by description |
board_name |
string |
query |
False |
Filter by board_name |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
type |
string |
query |
False |
Filter by type
serial_number |
string |
query |
False |
Filter by serial_number |
error.corrective_action |
string |
query |
False |
Filter by error.corrective_action |
error.message |
string |
query |
False |
Filter by error.message |
cable.identifier |
string |
query |
False |
Filter by cable.identifier |
cable.serial_number |
string |
query |
False |
Filter by cable.serial_number |
cable.part_number |
string |
query |
False |
Filter by cable.part_number |
cable.length |
string |
query |
False |
Filter by cable.length |
wwpn |
string |
query |
False |
Filter by wwpn
speed |
number |
query |
False |
Filter by speed |
wwn |
string |
query |
False |
Filter by wwn |
mode |
string |
query |
False |
Filter by mode
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[storage_port] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"board_name": "string",
"cable": {
"identifier": "500a0980000b6c3f-50000d1703544b80",
"length": "2m",
"part_number": "112-00431+A0",
"serial_number": 616930439
"description": "SAS Host Adapter 2a (PMC-Sierra PM8072 rev. C)",
"error": {
"corrective_action": "string",
"message": "string"
"firmware_version": "03.08.09.00",
"mac_address": "string",
"mode": "storage",
"name": "2a",
"node": {
"name": "node1",
"part_number": "111-03801",
"serial_number": "7A2463CC45B",
"speed": 6,
"state": "online",
"type": "sas",
"wwn": "50000d1703544b80",
"wwpn": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
cable
identifier |
string |
length |
string |
part_number |
string |
serial_number |
string |
error
corrective_action |
string |
Error corrective action |
message |
string |
Error message |
_links
self |
node
_links |
name |
string |
uuid |
string |
storage_port
board_name |
string |
cable |
description |
string |
enabled |
boolean |
error |
firmware_version |
string |
force |
boolean |
in_use |
boolean |
Specifies whether any devices are connected through this port |
mac_address |
string |
mode |
string |
Operational mode of a non-dedicated Ethernet port |
name |
string |
node |
part_number |
string |
redundant |
boolean |
Specifies whether all devices connected through this port have a redundant path from another port |
serial_number |
string |
speed |
number |
Operational port speed in Gbps |
state |
string |
type |
string |
wwn |
string |
World Wide Name |
wwpn |
string |
World Wide Port Name |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
