Retrieve the SnapLock ComplianceClock for nodes in a cluster
Retrieves the SnapLock ComplianceClock for all nodes in a cluster to monitor and manage compliance time settings effectively.
HTTP method and endpoint
GET /storage/snaplock/compliance-clocks
Introduced in
ONTAP 9.7
Usage notes
Retrieves the SnapLock ComplianceClock for all of the nodes in the cluster.
Related ONTAP commands
snaplock compliance-clock show
Learn more
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snaplock_compliance_clock] |
"next": {
"href": "/api/resourcelink"
"records": [
"node": {
"name": "node1",
"time": "2018-06-04T19:00:00Z"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
_links |
node |
time |
string |
Compliance clock time |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
