REST API reference
Retrieve the SnapLock ComplianceClock for nodes in a cluster
Retrieves the SnapLock ComplianceClock for all nodes in a cluster to monitor and manage compliance time settings effectively.
HTTP method and endpoint
GET /storage/snaplock/compliance-clocks
Introduced in
ONTAP 9.7
Usage notes
Retrieves the SnapLock ComplianceClock for all of the nodes in the cluster.
  • snaplock compliance-clock show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snaplock_compliance_clock]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "node": {
        "name": "node1",
      "time": "2018-06-04 19:00:00 +0000"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
_links
_links
node
node
time
string
Compliance clock time
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
