Manage the SnapLock ComplianceClock
Manage the ComplianceClock to control the expiry time of SnapLock objects within the system. You can initialize or re-initialize the ComplianceClock under specific conditions, such as when all nodes and volumes are healthy and online, and no SnapLock or object-locking volumes are present.
This API manages the ComplianceClock of the system. ComplianceClock determines the expiry time of the SnapLock objects in the system. The user can initialize the ComplianceClock. The ComplianceClock can be re-initialized if all nodes in the cluster are healthy, all volumes are in online state, no volumes are present in the volume recovery queue and there are no SnapLock volumes or volumes with "snapshot-locking-enabled" set to true or S3 buckets with object locking enabled.
