REST API reference
Display files for a litigation ID
Views the list of files associated with a specific litigation ID to assess information relevant to legal inquiries or audits.
HTTP method and endpoint
GET /storage/snaplock/litigations/{litigation.id}/files
Introduced in
ONTAP 9.7
Usage notes
Displays the list of files for the specified litigation ID.
litigation.id
string
path
True
Litigation ID
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
List of Files under the specified litigation.
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "file": [
        "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
records
file
array[string]
Name of the file including the path from the root.
sequence_index
integer
Sequence index of files path list.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
