Display files for a litigation ID
Displays the list of files associated with a specified litigation ID. This helps you review and manage files relevant to legal inquiries or obligations.
HTTP method and endpoint
GET /storage/snaplock/litigations/{litigation.id}/files
Introduced in
ONTAP 9.7
Usage notes
Displays the list of files for the specified litigation ID.
litigation.id |
string |
path |
True |
Litigation ID |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
List of Files under the specified litigation. |
"next": {
"href": "/api/resourcelink"
"records": [
"file": [
"string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
records
file |
array[string] |
Name of the file including the path from the root. |
sequence_index |
integer |
Sequence index of files path list. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
