Retrieve volume efficiency policies
Retrieves volume efficiency policies to review the collection of policies currently applied to manage storage efficiency across volumes. This helps you assess and optimize data storage strategies.
HTTP method and endpoint
GET /storage/volume-efficiency-policies
Introduced in
ONTAP 9.8
Usage notes
Retrieves a collection of volume efficiency policies.
Related ONTAP commands
volume efficiency policy show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
schedule.name |
string |
query |
False |
Filter by schedule.name |
name |
string |
query |
False |
Filter by name |
start_threshold_percent |
integer |
query |
False |
Filter by start_threshold_percent |
duration |
integer |
query |
False |
Filter by duration |
enabled |
boolean |
query |
False |
Filter by enabled |
qos_policy |
string |
query |
False |
Filter by qos_policy |
type |
string |
query |
False |
Filter by type |
comment |
string |
query |
False |
Filter by comment |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[volume_efficiency_policy] |
"next": {
"href": "/api/resourcelink"
"records": [
"comment": "string",
"duration": 5,
"enabled": 1,
"name": "default",
"qos_policy": "string",
"schedule": {
"name": "daily"
"start_threshold_percent": 30,
"svm": {
"name": "svm1",
"type": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
schedule
name |
string |
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
_links |
comment |
string |
A comment associated with the volume efficiency policy. |
duration |
integer |
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0. |
enabled |
boolean |
Is the volume efficiency policy enabled? |
name |
string |
Name of the volume efficiency policy. |
qos_policy |
string |
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations. |
schedule |
integer |
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule. |
svm |
type |
string |
Type of volume efficiency policy. |
uuid |
string |
Unique identifier of volume efficiency policy. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
