REST API reference
Retrieve volume efficiency policies
Retrieves a collection of volume efficiency policies to review and manage efficiency settings for volumes in your storage environment.
HTTP method and endpoint
GET /storage/volume-efficiency-policies
Introduced in
ONTAP 9.8
  • volume efficiency policy show
type
string
query
False
Filter by type
enabled
boolean
query
False
Filter by enabled
schedule.name
string
query
False
Filter by schedule.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
uuid
string
query
False
Filter by uuid
start_threshold_percent
integer
query
False
Filter by start_threshold_percent
qos_policy
string
query
False
Filter by qos_policy
comment
string
query
False
Filter by comment
name
string
query
False
Filter by name
duration
integer
query
False
Filter by duration
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[volume_efficiency_policy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "string",
      "name": "string",
      "qos_policy": "string",
      "schedule": {
        "name": "string"
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
schedule
name
string
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced.
svm
_links
_links
name
string
uuid
string
_links
_links
comment
string
A comment associated with the volume efficiency policy.
duration
integer
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0.
enabled
boolean
Is the volume efficiency policy enabled?
name
string
Name of the volume efficiency policy.
qos_policy
string
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations.
schedule
schedule
integer
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule.
svm
svm
type
string
Type of volume efficiency policy.
uuid
string
Unique identifier of volume efficiency policy.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
