Retrieve EMS configuration
Retrieves the EMS configuration to review the current event management settings in your system.
HTTP method and endpoint
GET /support/ems
Introduced in
ONTAP 9.6
Related ONTAP commands
event config show
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
mail_from |
string |
Mail from |
mail_server |
string |
Mail server (SMTP) |
proxy_password |
string |
Password for HTTP/HTTPS proxy |
proxy_url |
string |
HTTP/HTTPS proxy URL |
proxy_user |
string |
User name for HTTP/HTTPS proxy |
pubsub_enabled |
boolean |
Is Publish/Subscribe Messaging Enabled? |
"href": "/api/resourcelink"
"mail_from": "administrator@mycompany.com",
"mail_server": "mail@mycompany.com",
"proxy_password": "password",
"proxy_url": "https://proxyserver.mycompany.com",
"proxy_user": "proxy_user",
"pubsub_enabled": 1
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
