REST API reference
Retrieve an EMS configuration
Retrieves the EMS configuration to review the current event management settings in your system.
HTTP method and endpoint
GET /support/ems
Introduced in
ONTAP 9.6
  • event config show
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
mail_from
string
Mail from
mail_server
string
Mail server (SMTP)
proxy_password
string
Password for HTTP/HTTPS proxy
proxy_url
string
HTTP/HTTPS proxy URL
proxy_user
string
User name for HTTP/HTTPS proxy
pubsub_enabled
boolean
Is Publish/Subscribe Messaging Enabled?
      "href": "/api/resourcelink"
  "mail_from": "administrator@mycompany.com",
  "mail_server": "mail.mycompany.com",
  "proxy_password": "password",
  "proxy_url": "https://proxyserver.mycompany.com",
  "proxy_user": "proxy_user",
  "pubsub_enabled": 1
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
