Retrieve EMS configuration
GET /support/ems
Retrieves the EMS configuration.
Related ONTAP commands
event config show
Learn more
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
mail_from |
string |
Mail from |
mail_server |
string |
Mail server (SMTP) |
proxy_password |
string |
Password for HTTP/HTTPS proxy |
proxy_url |
string |
HTTP/HTTPS proxy URL |
proxy_user |
string |
User name for HTTP/HTTPS proxy |
"href": "/api/resourcelink"
"mail_from": "administrator@mycompany.com",
"mail_server": "mail@mycompany.com",
"proxy_password": "password",
"proxy_url": "https://proxyserver.mycompany.com",
"proxy_user": "proxy_user"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
