Retrieve SNMP users on a cluster
Retrieves the list of SNMP users on the cluster to manage and configure SNMP access effectively.
HTTP method and endpoint
GET /support/snmp/users
Introduced in
ONTAP 9.7
Related ONTAP commands
security snmpusers -
security login show -application snmp
Learn more
engine_id |
string |
query |
False |
Filter by engine_id |
comment |
string |
query |
False |
Filter by comment |
scope |
string |
query |
False |
Filter by scope |
authentication_method |
string |
query |
False |
Filter by authentication_method |
snmpv3.authentication_protocol |
string |
query |
False |
Filter by snmpv3.authentication_protocol |
snmpv3.privacy_protocol |
string |
query |
False |
Filter by snmpv3.privacy_protocol |
switch_address |
string |
query |
False |
Filter by switch_address |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[snmp_user] |
"next": {
"href": "/api/resourcelink"
"records": [
"authentication_method": "usm",
"comment": "This is a comment.",
"engine_id": "80000315055415ab26d4aae811ac4d005056bb792e",
"name": "snmpv3user2",
"owner": {
"name": "svm1",
"scope": "svm",
"snmpv3": {
"authentication_protocol": "sha2_256",
"privacy_protocol": "aes128"
"switch_address": "10.23.34.45"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
Optional name and UUID of owning Storage Virtual Machine (SVM).
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snmpv3
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user.
_links |
string |
Authentication protocol. |
privacy_protocol |
string |
Privacy protocol. |
snmp_user
An SNMP user can be an SNMPv1/SNMPv2c user or an SNMPv3 user. SNMPv1/SNMPv2c user is also called a "community" user. An SNMPv3 user, also called a User-based Security Model (USM) user, can be a local SNMPv3 user or a remote SNMPv3 user. A local SNMPv3 user can be used for querying ONTAP SNMP server over SNMPv3 and/or for sending SNMPv3 traps. The local SNMPv3 user used for sending SNMPv3 traps must be configured with the same authentication and privacy credentials on the traphost receiver as well. A remote SNMPv3 user is also configured on a remote switch and used by ONTAP SNMP client functionality to query the remote switch over SNMPv3. An SNMP user is scoped to its owning Storage Virtual Machine (SVM). Owning SVM could be a data SVM or the administrative SVM.
_links |
string |
Optional authentication method. |
comment |
string |
Optional comment text. |
engine_id |
string |
Optional SNMPv3 engine identifier. For a local SNMP user belonging to the administrative Storage Virtual Machine (SVM), the default value of this parameter is the SNMPv3 engine identifier for the administrative SVM. For a local SNMP user belonging to a data SVM, the default value of this parameter is the SNMPv3 engine identifier for that data SVM. For an SNMPv1/SNMPv2c community, this parameter should not be specified in "POST" method. For a remote switch SNMPv3 user, this parameter specifies the SNMPv3 engine identifier for the remote switch. This parameter can also optionally specify a custom engine identifier. |
name |
string |
SNMP user name. |
owner |
Optional name and UUID of owning Storage Virtual Machine (SVM). |
scope |
string |
Set to "svm" for data Storage Virtual Machine (SVM) SNMP users and to "cluster" for administrative SVM SNMP users. |
snmpv3 |
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user. |
switch_address |
string |
Optional remote switch address. It can be an IPv4 address or an IPv6 address. A remote switch can be queried over SNMPv3 using ONTAP SNMP client functionality. Querying such a switch requires an SNMPv3 user (remote switch user) to be configured on the switch. Since ONTAP requires remote switch user's SNMPv3 credentials (to query it), this user must be configured in ONTAP as well. This parameter is specified when configuring such a user.
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
