REST API reference
Retrieve SNMP users on a cluster
Retrieves a list of SNMP users configured on your cluster. Use this information to manage SNMP user access and settings.
HTTP method and endpoint
GET /support/snmp/users
Introduced in
ONTAP 9.7
Usage notes
Retrieves the list of SNMP users on the cluster.
  • security snmpusers
  • security login show -application snmp
owner.name
string
query
False
Filter by owner.name
owner.uuid
string
query
False
Filter by owner.uuid
comment
string
query
False
Filter by comment
  • maxLength: 128
  • minLength: 0
name
string
query
False
Filter by name
  • maxLength: 32
switch_address
string
query
False
Filter by switch_address
snmpv3.authentication_protocol
string
query
False
Filter by snmpv3.authentication_protocol
snmpv3.privacy_protocol
string
query
False
Filter by snmpv3.privacy_protocol
authentication_method
string
query
False
Filter by authentication_method
scope
string
query
False
Filter by scope
engine_id
string
query
False
Filter by engine_id
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[snmp_user]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication_method": "usm",
      "comment": "This is a comment.",
      "engine_id": "80000315055415ab26d4aae811ac4d005056bb792e",
      "name": "snmpv3user2",
      "owner": {
        "name": "svm1",
      "scope": "svm",
      "snmpv3": {
        "authentication_protocol": "sha2_256",
        "privacy_protocol": "aes128"
      "switch_address": "10.23.34.45"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
Optional name and UUID of owning Storage Virtual Machine (SVM).
_links
_links
name
string
uuid
string
snmpv3
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user.
_links
_links
string
Authentication protocol.
privacy_protocol
string
Privacy protocol.
snmp_user
An SNMP user can be an SNMPv1/SNMPv2c user or an SNMPv3 user. SNMPv1/SNMPv2c user is also called a "community" user. An SNMPv3 user, also called a User-based Security Model (USM) user, can be a local SNMPv3 user or a remote SNMPv3 user. A local SNMPv3 user can be used for querying ONTAP SNMP server over SNMPv3 and/or for sending SNMPv3 traps. The local SNMPv3 user used for sending SNMPv3 traps must be configured with the same authentication and privacy credentials on the traphost receiver as well. A remote SNMPv3 user is also configured on a remote switch and used by ONTAP SNMP client functionality to query the remote switch over SNMPv3. An SNMP user is scoped to its owning Storage Virtual Machine (SVM). Owning SVM could be a data SVM or the administrative SVM.
_links
_links
string
Optional authentication method.
comment
string
Optional comment text.
engine_id
string
Optional SNMPv3 engine identifier. For a local SNMP user belonging to the administrative Storage Virtual Machine (SVM), the default value of this parameter is the SNMPv3 engine identifier for the administrative SVM. For a local SNMP user belonging to a data SVM, the default value of this parameter is the SNMPv3 engine identifier for that data SVM. For an SNMPv1/SNMPv2c community, this parameter should not be specified in "POST" method. For a remote switch SNMPv3 user, this parameter specifies the SNMPv3 engine identifier for the remote switch. This parameter can also optionally specify a custom engine identifier.
name
string
SNMP user name.
owner
owner
scope
string
Set to "svm" for data Storage Virtual Machine (SVM) SNMP users and to "cluster" for administrative SVM SNMP users.
snmpv3
snmpv3
switch_address
string
Optional remote switch address. It can be an IPv4 address or an IPv6 address. A remote switch can be queried over SNMPv3 using ONTAP SNMP client functionality. Querying such a switch requires an SNMPv3 user (remote switch user) to be configured on the switch. Since ONTAP requires remote switch user's SNMPv3 credentials (to query it), this user must be configured in ONTAP as well. This parameter is specified when configuring such a user.
  • example: 10.23.34.45
  • Introduced in: 9.7
  • readCreate: 1
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
