Retrieve and create SNMP users
Use these endpoints to define, retrieve, and create SNMP users within your cluster. You can manage SNMPv1/SNMPv2c community users for querying the ONTAP SNMP server or configure SNMPv3 users for enhanced security and remote querying capabilities.
Overview
Defines, retrieves and adds new SNMP users. An SNMP user can be an SNMPv1/SNMPv2c user or an SNMPv3 user. SNMPv1/SNMPv2c user is also called a "community" user. Use a "community" user to query ONTAP SNMP server over SNMPv1/SNMPv2c protocol. An SNMPv3 user, also called a User-based Security Model (USM) user, can be a local SNMPv3 user or a remote SNMPv3 user. Use a local SNMPv3 user to query ONTAP SNMP server over SNMPv3 and/or to send SNMPv3 traps. A remote SNMPv3 user is configured in ONTAP as well as on a remote switch. ONTAP SNMP client uses a remote SNMPv3 user to query the switch over SNMPv3.
Retrieves a list of SNMP users in the cluster, sorted by SVM UUID
# The API:
GET "/api/support/snmp/users"
# The call:
curl -H "accept: application/hal+json" -X GET "https://<mgmt-ip>/api/support/snmp/users?order_by=owner.uuid"
# The response:
"records": [
"engine_id": "80000315052d7d2c4410b8e911bc9f005056bb942e",
"name": "snmpv1user1",
"owner": {
"uuid": "442c7d2d-b810-11e9-bc9f-005056bb942e"
"href": "/api/support/snmp/users/80000315052d7d2c4410b8e911bc9f005056bb942e/snmpv1user1"
"engine_id": "80000315058e02057c0fb8e911bc9f005056bb942e",
"name": "snmpv3user1",
"owner": {
"uuid": "7c05028e-b80f-11e9-bc9f-005056bb942e"
"href": "/api/support/snmp/users/80000315058e02057c0fb8e911bc9f005056bb942e/snmpv3user1"
"num_records": 2,
"href": "/api/support/snmp/users?order_by=owner.uuid"
Creates an SNMPv1 or SNMPv2c community user
# The API:
POST "/api/support/snmp/users"
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/users" -d '{"owner":{"uuid":"02c9e252-41be-11e9-81d5-00a0986138f7", "name":"cluster1"}, "name":"public", "authentication_method":"community"}'
# The response:
201 Created
Creates a local SNMPv3 user
# The API:
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/users" -d '{"owner":{"uuid":"02c9e252-41be-11e9-81d5-00a0986138f7", "name":"cluster1"}, "name":"snmpv3u1", "authentication_method":"usm", "snmpv3":{"authentication_protocol":"sha", "authentication_password":"jelly22fi$h", "privacy_protocol":"aes", "privacy_password":"a11Black$"}}'
# The response:
201 Created
Creates a remote SNMPv3 user
# The API:
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/users" -d '{"owner":{"uuid":"02c9e252-41be-11e9-81d5-00a0986138f7", "name":"cluster1"}, "engine_id":"8000031505b67667a26975e9118a480050568e6f74", "name":"switchuser1", "authentication_method":"usm", "switch_address":"fdf8:f53b:82e4::53", "snmpv3":{"authentication_protocol":"md5", "authentication_password":"TfhIeliw601lS.Rw$3pm"}}'
# The response:
201 Created
