REST API reference
Retrieve and create SNMP users
Define, retrieve, and create SNMP users to facilitate communication with ONTAP SNMP servers over SNMPv1/SNMPv2c or SNMPv3 protocols. Use community users for SNMPv1/SNMPv2c queries, local SNMPv3 users for SNMPv3 queries and trap sending, and configure remote SNMPv3 users for querying switches.
Overview
Defines, retrieves and adds new SNMP users. An SNMP user can be an SNMPv1/SNMPv2c user or an SNMPv3 user. SNMPv1/SNMPv2c user is also called a "community" user. Use a "community" user to query ONTAP SNMP server over SNMPv1/SNMPv2c protocol. An SNMPv3 user, also called a User-based Security Model (USM) user, can be a local SNMPv3 user or a remote SNMPv3 user. Use a local SNMPv3 user to query ONTAP SNMP server over SNMPv3 and/or to send SNMPv3 traps. A remote SNMPv3 user is configured in ONTAP as well as on a remote switch. ONTAP SNMP client uses a remote SNMPv3 user to query the switch over SNMPv3.
Retrieves a list of SNMP users in the cluster, sorted by SVM UUID
# The API:
GET "/api/support/snmp/users"
# The call:
curl -H "accept: application/hal+json" -X GET "https://<mgmt-ip>/api/support/snmp/users?order_by=owner.uuid"
# The response:
"records": [
    "engine_id": "80000315052d7d2c4410b8e911bc9f005056bb942e",
    "name": "snmpv1user1",
    "owner": {
      "uuid": "442c7d2d-b810-11e9-bc9f-005056bb942e"
        "href": "/api/support/snmp/users/80000315052d7d2c4410b8e911bc9f005056bb942e/snmpv1user1"
    "engine_id": "80000315058e02057c0fb8e911bc9f005056bb942e",
    "name": "snmpv3user1",
    "owner": {
      "uuid": "7c05028e-b80f-11e9-bc9f-005056bb942e"
        "href": "/api/support/snmp/users/80000315058e02057c0fb8e911bc9f005056bb942e/snmpv3user1"
"num_records": 2,
    "href": "/api/support/snmp/users?order_by=owner.uuid"
Creates an SNMPv1 or SNMPv2c community user
# The API:
POST "/api/support/snmp/users"
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/users" -d '{"owner":{"uuid":"02c9e252-41be-11e9-81d5-00a0986138f7", "name":"cluster1"}, "name":"public", "authentication_method":"community"}'
# The response:
201 Created
Creates a local SNMPv3 user
# The API:
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/users" -d '{"owner":{"uuid":"02c9e252-41be-11e9-81d5-00a0986138f7", "name":"cluster1"}, "name":"snmpv3u1", "authentication_method":"usm", "snmpv3":{"authentication_protocol":"sha", "authentication_password":"jelly22fi$h", "privacy_protocol":"aes", "privacy_password":"a11Black$"}}'
# The response:
201 Created
Creates a remote SNMPv3 user
# The API:
# The call
curl -H "accept: application/json" -H "Content-Type: application/json" -X POST "https://<mgmt-ip>/api/support/snmp/users" -d '{"owner":{"uuid":"02c9e252-41be-11e9-81d5-00a0986138f7", "name":"cluster1"}, "engine_id":"8000031505b67667a26975e9118a480050568e6f74", "name":"switchuser1", "authentication_method":"usm", "switch_address":"fdf8:f53b:82e4::53", "snmpv3":{"authentication_protocol":"md5", "authentication_password":"TfhIeliw601lS.Rw$3pm"}}'
# The response:
201 Created
