REST API reference
Retrieve migration status for an SVM
Retrieves the migration status of a specific SVM to monitor and manage its migration process effectively.
HTTP method and endpoint
GET /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the migration status of an individual SVM.
Important notes
  • The "migrations" object includes a large set of fields and can be expensive to retrieve.
  • REST APIs only expose a data SVM as an SVM.
Example
Retrieving an individual SVM migration status.
  GET "/api/svm/migrations/a14ae39f-8d85-11e9-b4a7-00505682dc8b/svms/f16f0935-5281-11e8-b94d-005056b46485"
uuid
string
path
True
Migration UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
auto_cutover
boolean
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover".
auto_source_cleanup
boolean
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover.
current_operation
string
destination
destination
Destination cluster details for the SVM migration.
last_failed_state
string
Indicates the state of the migration.
last_operation
string
messages
array[messages]
Errors and warnings returned/displayed during migration.
point_of_no_return
boolean
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted.
restart_count
integer
Number of times SVM migration was restarted since initially started.
source
source
Source cluster details for the SVM migration.
state
string
time_metrics
time_metrics
Various time metrics details
uuid
string
SVM migration UUID
  "check_only": null,
  "current_operation": "string",
  "destination": {
    "ipspace": {
          "href": "/api/resourcelink"
      "name": "exchange",
    "volume_placement": {
      "aggregates": [
          "name": "aggr1",
  "last_failed_state": "string",
  "last_operation": "string",
  "messages": [
      "message": "string"
  "restart_count": 0,
  "source": {
    "cluster": {
      "name": "cluster1",
    "svm": {
      "name": "svm1",
  "state": "string",
  "time_metrics": {
    "cutover_complete_time": "2020-12-02T19:30:19-08:00",
    "cutover_start_time": "2020-12-02T18:20:19-08:00",
    "cutover_trigger_time": "2020-12-02T19:15:19-08:00",
    "end_time": "2020-12-02T19:36:19-08:00",
    "last_pause_time": "2020-12-02T18:50:19-08:00",
    "last_resume_time": "2020-12-02T18:54:19-08:00",
    "start_time": "2020-12-02T18:36:19-08:00"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
aggregates
Aggregate
_links
_links
name
string
uuid
string
volume_placement
Optional property to specify the source volume placement in the destination.
aggregates
array[aggregates]
Optional property used to specify the list of desired aggregates to use for volume creation in the destination.
destination
ipspace
ipspace
volume_placement
volume_placement
messages
Specifies failure codes and messages.
code
integer
Message code
message
string
Detailed message of warning or error.
cluster
Source cluster for the SVM migration.
_links
_links
name
string
uuid
string
svm
Source SVM
_links
_links
name
string
The name of the SVM.
uuid
string
source
cluster
cluster
svm
svm
Source SVM
time_metrics
string
Cutover end time
cutover_start_time
string
Cutover start time
string
Cutover trigger time
end_time
string
Migration end time
last_pause_time
string
Last migration pause time
last_resume_time
string
Last migration resume time
start_time
string
Migration start time
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
