Retrieve the migration status for an SVM
Retrieves the migration status of a specific SVM to monitor its progress and address any issues that arise during the migration process.
HTTP method and endpoint
GET /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the migration status of an individual SVM.
Important notes
The "migrations" object includes a large set of fields and can be expensive to retrieve.
REST APIs only expose a data SVM as an SVM.
There are subsystem specific errors that can be returned from this endpoint. If a subsystem specific error is returned and this is the first migrate operation attempt, it is embedded in one of the following errors. If a subsystem specific error is returned and this is not the first migrate operation attempt, the subsystem specific error is returned directly.
Example
Retrieving an individual SVM migration status.
GET "/api/svm/migrations/a14ae39f-8d85-11e9-b4a7-00505682dc8b/svms/f16f0935-5281-11e8-b94d-005056b46485"
uuid |
string |
path |
True |
Migration UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
auto_cutover |
boolean |
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover". |
auto_source_cleanup |
boolean |
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover. |
current_operation |
string |
destination |
Destination cluster details for the SVM migration. |
last_failed_state |
string |
Indicates the state of the migration. |
last_operation |
string |
messages |
array[messages] |
Errors and warnings returned/displayed during migration. |
point_of_no_return |
boolean |
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted. |
restart_count |
integer |
Number of times migrate restarted the transfer, for example, rollback to transfer after starting the cutover. |
source |
Source cluster details for the SVM migration. |
state |
string |
throttle |
integer |
Optional property to specify a throttle value in KB/s for each individual volume transfer. Defaults to 0 if not set, which is interpreted as unlimited. The minimum throttle value is 4 KB/s, so if you specify a throttle value between 1 and 4, it will be treated as if you specified 4. |
time_metrics |
Various time metrics details |
uuid |
string |
SVM migration UUID |
"check_only": true,
"current_operation": "string",
"destination": {
"ipspace": {
"href": "/api/resourcelink"
"name": "exchange",
"last_failed_state": "string",
"last_operation": "string",
"messages": [
"code": "string",
"message": "string"
"restart_count": 0,
"source": {
"cluster": {
"name": "cluster1",
"svm": {
"name": "svm1",
"state": "string",
"throttle": 0,
"time_metrics": {
"cutover_complete_time": "2020-12-02 22:30:19 -0500",
"cutover_start_time": "2020-12-02 21:20:19 -0500",
"cutover_trigger_time": "2020-12-02 22:15:19 -0500",
"end_time": "2020-12-02 22:36:19 -0500",
"last_pause_time": "2020-12-02 21:50:19 -0500",
"last_resume_time": "2020-12-02 21:54:19 -0500",
"start_time": "2020-12-02 21:36:19 -0500"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13172783 |
Migrate RDB lookup failed |
13173739 |
Migrate pause operation failed. Retry pause operation using REST API PATCH method \"/api/svm/migrations/ |
13173740 |
Migrate abort operation failed. Retry abort operation by using REST API DELETE method \"/api/svm/migrations/ |
13173741 |
Migrate failed. Retry the migrate by running the resume operation using REST API PATCH method \"/api/svm/migrations/ |
13173742 |
Migrate operation status: {Reason}. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
aggregate
Aggregate to use for volume creation.
_links |
name |
string |
uuid |
string |
volume
Property indicating the source volume.
_links |
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
volume_aggregate_pairs
Volume-aggregate pair information.
aggregate |
Aggregate to use for volume creation. |
volume |
Property indicating the source volume. |
volume_placement
Optional property to specify the source volume placement in the destination. It is input only and won't be returned by a subsequent GET. Volume placement is ignored if the migration resumes from the cleanup_failed state.
aggregates |
array[aggregates] |
Optional property used to specify the list of desired aggregates to use for volume creation in the destination. |
volume_aggregate_pairs |
array[volume_aggregate_pairs] |
Optional property used to specify the list of desired volume-aggregate pairs in the destination. |
destination
ipspace |
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Network interface on the source SVM.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
node
name |
string |
Name of node on which the port is located. |
port
Port to use for IP interface placement on the destination SVM.
_links |
name |
string |
node |
uuid |
string |
ip_interfaces
IP interface and network port pair information.
interface |
Network interface on the source SVM. |
port |
Port to use for IP interface placement on the destination SVM. |
svm_migration_ip_interface_placement
Optional property used to specify the list of source SVM's IP interface and network port pairs in the destination for migrating the source SVM IP interfaces. Note that the SVM migration does not perform any reachability checks on the IP interfaces provided.
ip_interfaces |
array[ip_interfaces] |
List of source SVM's IP interface and port pairs on the destination for migrating the source SVM's IP interfaces. |
messages
code |
string |
Argument code |
message |
string |
Message argument |
cluster
Source cluster for the SVM migration.
_links |
name |
string |
uuid |
string |
svm
Source SVM
_links |
name |
string |
uuid |
string |
source
cluster |
Source cluster for the SVM migration. |
svm |
Source SVM |
time_metrics
cutover_complete_time |
string |
Cutover end time |
cutover_start_time |
string |
Cutover start time |
cutover_trigger_time |
string |
Cutover trigger time |
end_time |
string |
Migration end time |
last_pause_time |
string |
Last migration pause time |
last_resume_time |
string |
Last migration resume time |
start_time |
string |
Migration start time |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
