Manage an event destination instance
Manage specific instances of event destinations to customize notifications and alerts within your environment. While certain details can be modified, some properties like the destination type remain fixed after creation. Default system-defined destinations are immutable and cannot be deleted or altered.
Overview
Manages a specific instance of a destination. There are limits to the information that you can modify after a destination is created. For example, you cannot change a destination's type, but you can modify the underlying details of the type.
The system defines default destinations that cannot be removed or modified. These destinations are specified by setting the "system_defined" field to "true". |
See the documentation for /support/ems/destinations for details on the various properties in a destination.
Retrieving a specific destination instance
# The API:
GET /api/support/ems/destinations/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/destinations/snmp-traphost" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "snmp-traphost",
"type": "snmp",
"destination": "",
"filters": [
"name": "default-trap-events",
"href": "/api/support/ems/filters/default-trap-events"
"href": "/api/support/ems/destinations/snmp-traphost"
Updating an existing destination (change of email address)
# The API:
PATCH /api/support/ems/destinations/{name}
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations/test-destination" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_destinations_patch.txt"
test_ems_destinations_patch.txt(body):
"destination": "support@mycompany.com"
# The response:
200 OK
Deleting an existing destination
# The API:
DELETE /api/support/ems/destinations/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/destinations/test-destination" -H "accept: application/hal+json"
# The response:
200 OK
