Manage an event destination instance
Manage instances of event destinations by modifying their properties, except for the destination type, which remains fixed after creation. Use these endpoints to retrieve, update, or delete specific destination instances as needed.
Overview
Manages a specific instance of a destination. There are limits to the information that you can modify after a destination is created. For example, you cannot change a destination's type, but you can modify the underlying details of the type. See the documentation for /support/ems/destinations for details on the various properties in a destination.
Retrieving a specific destination instance
# API
GET /api/support/ems/destinations/snmp-traphost
# Response
200 OK
# JSON Body
"name": "snmp-traphost",
"type": "snmp",
"destination": "",
"filters": [
"name": "default-trap-events",
"href": "/api/support/ems/filters/default-trap-events"
"href": "/api/support/ems/destinations/snmp-traphost"
Updating an existing destination (change of email address)
# API
PATCH /api/support/ems/destinations/test-destination
# JSON Body
"destination": "support@mycompany.com"
# Response
200 OK
Deleting an existing destination
# API
DELETE /api/support/ems/destinations/test-destination
# Response
200 OK
