Manage storage bridges
Retrieve information about storage bridges within the cluster using the storage bridge GET API. These endpoints help you monitor and manage the bridges effectively by accessing detailed attributes for each bridge.
Retrieving storage bridge information
The storage bridge GET API retrieves all of the bridges in the cluster.
1) Retrieves a list of bridges from the cluster
The following example shows the response with a list of bridges from the cluster:
# The API:
/api/storage/bridges
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges" -H "accept: application/hal+json"
# The response:
"records": [
"wwn": "2000001086a18100",
"name": "ATTO_2000001086a18100",
"href": "/api/storage/bridges/2000001086a18100"
"wwn": "2000001086a18380",
"name": "ATTO_2000001086a18380",
"href": "/api/storage/bridges/2000001086a18380"
"num_records": 2,
"href": "/api/storage/bridges/"
2) Retrieves a specific bridge from the cluster
The following example shows the response of the requested bridge. If there is no bridge with the requested wwn, an error is returned.
# The API:
/api/storage/bridges/{wwn}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges/2000001086a18100" -H "accept: application/hal+json"
# The response:
"chassis_throughput_state": "ok",
"dram_single_bit_error_count": 0,
"firmware_version": "3.10 007A",
"ip_address": "10.226.57.178",
"security_enabled": false,
"monitoring_enabled": true,
"model": "FibreBridge 7500N",
"state": "ok",
"managed_by": "in_band",
"serial_number": "FB7500N102450",
"symbolic_name": "RTP-FCSAS02-41KK10",
"vendor": "atto",
"last_reboot": {
"reason": {
"message": "Reason: \"FirmwareRestart Command\".",
"code": "39321683"
"time": "2020-12-09T00:47:58-05:00"
"paths": [
"name": "0e",
"node": {
"name": "sti8080mcc-htp-005",
"uuid": "ecc3d992-3a86-11eb-9fab-00a0985a6024",
"href": "/api/cluster/nodes/ecc3d992-3a86-11eb-9fab-00a0985a6024"
"href": "/api/storage/ports/ecc3d992-3a86-11eb-9fab-00a0985a6024/0e"
"target_port": {
"wwn": "2100001086a18380"
"temperature_sensor": {
"name": "Chassis Temperature Sensor",
"minimum": 0,
"maximum": 90,
"reading": 54,
"state": "ok"
"fc_ports": [
"id": 1,
"state": "online",
"enabled": true,
"negotiated_data_rate": 8,
"configured_data_rate": 8,
"conn_mode": "ptp",
"data_rate_capability": 16,
"wwn": "2100001086a18100",
"peer_wwn": "0000000000000000",
"sfp": {
"vendor": "FINISAR CORP.",
"serial_number": "UW106SA",
"part_number": "FTLF8529P3BCV",
"id": 2,
"state": "online",
"enabled": true,
"negotiated_data_rate": 16,
"configured_data_rate": 16,
"conn_mode": "ptp",
"wwn": "2200001086a18100",
"sfp": {
"serial_number": "UW1072B",
"power_supply_units": [
"name": "A",
"state": "ok"
"name": "B",
"state": "ok"
"sas_ports": [
"id": 1,
"state": "online",
"enabled": true,
"data_rate_capability": 12,
"negotiated_data_rate": 6,
"wwn": "5001086000a18100",
"phy_1": {
"state": "online"
"phy_2": {
"state": "online"
"phy_3": {
"state": "online"
"phy_4": {
"state": "online"
"cable": {
"vendor": "Molex Inc.",
"serial_number": "618130935",
"technology": "Passive Copper 5m ID:00",
"part_number": "112-00431"
"state": "offline",
"enabled": false,
"negotiated_data_rate": 0,
"wwn": "5001086000a18104",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a18108",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a1810c",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
