Manage storage bridges
Retrieve and manage information about storage bridges within the cluster using these endpoints. Access detailed data for each bridge to monitor performance and ensure connectivity.
Retrieving storage bridge information
The storage bridge GET API retrieves all of the bridges in the cluster.
1) Retrieves a list of bridges from the cluster
The following example shows the response with a list of bridges from the cluster:
# The API:
/api/storage/bridges
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges" -H "accept: application/hal+json"
# The response:
"records": [
"wwn": "2000001086a18100",
"name": "ATTO_2000001086a18100",
"href": "/api/storage/bridges/2000001086a18100"
"wwn": "2000001086a18380",
"name": "ATTO_2000001086a18380",
"href": "/api/storage/bridges/2000001086a18380"
"num_records": 2,
"href": "/api/storage/bridges/"
2) Retrieves a specific bridge from the cluster
The following example shows the response of the requested bridge. If there is no bridge with the requested wwn, an error is returned.
# The API:
/api/storage/bridges/{wwn}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges/2000001086a18100" -H "accept: application/hal+json"
# The response:
"chassis_throughput_state": "ok",
"dram_single_bit_error_count": 0,
"firmware_version": "3.10 007A",
"ip_address": "10.226.57.178",
"security_enabled": false,
"monitoring_enabled": true,
"model": "FibreBridge 7500N",
"state": "ok",
"managed_by": "in_band",
"serial_number": "FB7500N102450",
"symbolic_name": "RTP-FCSAS02-41KK10",
"vendor": "atto",
"last_reboot": {
"reason": {
"message": "Reason: \"FirmwareRestart Command\".",
"code": "39321683"
"time": "2020-12-09T00:47:58-05:00"
"paths": [
"name": "0e",
"node": {
"name": "sti8080mcc-htp-005",
"uuid": "ecc3d992-3a86-11eb-9fab-00a0985a6024",
"href": "/api/cluster/nodes/ecc3d992-3a86-11eb-9fab-00a0985a6024"
"href": "/api/storage/ports/ecc3d992-3a86-11eb-9fab-00a0985a6024/0e"
"target_port": {
"wwn": "2100001086a18380"
"temperature_sensor": {
"name": "Chassis Temperature Sensor",
"minimum": 0,
"maximum": 90,
"reading": 54,
"state": "ok"
"fc_ports": [
"id": 1,
"state": "online",
"enabled": true,
"negotiated_data_rate": 8,
"configured_data_rate": 8,
"conn_mode": "ptp",
"data_rate_capability": 16,
"wwn": "2100001086a18100",
"peer_wwn": "0000000000000000",
"sfp": {
"vendor": "FINISAR CORP.",
"serial_number": "UW106SA",
"part_number": "FTLF8529P3BCV",
"id": 2,
"state": "online",
"enabled": true,
"negotiated_data_rate": 16,
"configured_data_rate": 16,
"conn_mode": "ptp",
"wwn": "2200001086a18100",
"sfp": {
"serial_number": "UW1072B",
"power_supply_units": [
"name": "A",
"state": "ok"
"name": "B",
"state": "ok"
"sas_ports": [
"id": 1,
"state": "online",
"enabled": true,
"data_rate_capability": 12,
"negotiated_data_rate": 6,
"wwn": "5001086000a18100",
"phy_1": {
"state": "online"
"phy_2": {
"state": "online"
"phy_3": {
"state": "online"
"phy_4": {
"state": "online"
"cable": {
"vendor": "Molex Inc.",
"serial_number": "618130935",
"technology": "Passive Copper 5m ID:00",
"part_number": "112-00431"
"state": "offline",
"enabled": false,
"negotiated_data_rate": 0,
"wwn": "5001086000a18104",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a18108",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a1810c",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
