Manage storage montiored files
Manage monitored files within your storage environment to track and control file-level operations. Use these endpoints to retrieve, provision, and remove files from the monitored list, ensuring efficient oversight of file performance.
Retrieving all monitored files
# The API: GET /api/storage/monitored-files # The call: curl -X GET "https://<mgmt-ip>/api/storage/monitored-files"
Provisioning a monitored file
# The API:
POST /api/storage/monitored-files
# The call:
curl -d "@test_mfiles_post.txt" -X POST "https://<mgmt-ip>/api/storage/monitored-files"
test_mfiles_post.txt(body):
"svm": {
"name": "vs0"
"volume": {
"name": "vol1"
"path": "/a/b/c/file.txt"
Removing a file from the monitored files list
# The API:
DELETE /api/storage/monitored-files/{uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/monitored-files/6f68c85b-45e1-11e9-8fc7-005056bbc848"
Alternate method for removing files from the monitored files list
Monitored files can also be deleted via a combination of any of (uuid, svm.name, svm.uuid, volume.name, volume.uuid, path). For example, to remove all monitored-files from monitoring in a single svm named vs0, use the following
# The API: DELETE /api/storage/monitored-files # The call: curl -X DELETE "https://<mgmt-ip>/api/storage/monitored-files?svm.name=vs0"
Performance monitoring
Performance of the monitored file can be monitored by the metric.* and statistics.* properties. These fields show the performance of the monitored file in terms of IOPS, latency and throughput. The metric.* properties denote an average whereas statistics.* properties denote a real-time monotonically increasing value aggregated across all nodes.
