Manage storage montiored files
Manage monitored files within your storage environment to efficiently track and maintain performance metrics. Use these endpoints to retrieve, provision, and remove monitored files, ensuring optimized data management and monitoring capabilities.
Retrieving all monitored files
# The API: GET /api/storage/monitored-files # The call: curl -X GET "https://<mgmt-ip>/api/storage/monitored-files"
Provisioning a monitored file
# The API:
POST /api/storage/monitored-files
# The call:
curl -d "@test_mfiles_post.txt" -X POST "https://<mgmt-ip>/api/storage/monitored-files"
test_mfiles_post.txt(body):
"svm": {
"name": "vs0"
"volume": {
"name": "vol1"
"path": "/a/b/c/file.txt"
Removing a file from the monitored files list
# The API:
DELETE /api/storage/monitored-files/{uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/monitored-files/6f68c85b-45e1-11e9-8fc7-005056bbc848"
Alternate method for removing files from the monitored files list
Monitored files can also be deleted via a combination of any of (uuid, svm.name, svm.uuid, volume.name, volume.uuid, path). For example, to remove all monitored-files from monitoring in a single svm named vs0, use the following
# The API: DELETE /api/storage/monitored-files # The call: curl -X DELETE "https://<mgmt-ip>/api/storage/monitored-files?svm.name=vs0"
Performance monitoring
Performance of the monitored file can be monitored by the metric.* and statistics.* properties. These fields show the performance of the monitored file in terms of IOPS, latency and throughput. The metric.* properties denote an average whereas statistics.* properties denote a real-time monotonically increasing value aggregated across all nodes.
