REST API reference
Updates a consistency group
n/a there are no ontap commands for managing consistency groups examples # adding luns to an existing volume in an existing consistency group adds two nvme namespaces to an existing volume in an existing consistency group, creates a new subsystem, and binds the new namespaces to it ` curl -x patch -k -u admin:netapp1! https://netapp-clusternetappcom/api/application/consistency-groups/6f48d798-0a7f-11ec-a449-005056bbcf9f -d { "luns": [ { "name": "/vol/vol1/new_luns", "provisioning_options": { "count": 2, "action": "create" }, "space": { "size": "100mb" }, "os_type": "linux", "lun_maps": [ { "igroup": { "name": "igroup2", "initiators": [ { "name": "01:02:03:04:05:06:07:01" } ] } } ] } ] } ` # response: ` { "job": { "uuid": "5306ea44-0a87-11ec-a449-005056bbcf9f", "_links": { "self": { "href": "/api/cluster/jobs/5306ea44-0a87-11ec-a449-005056bbcf9f" } } } } ` adding namespaces to an existing volume in an existing consistency group add 2 nvme namespaces to an existing volume in an existing consistency group, create a new subsystem and bind the new namespaces to it ` curl -x patch -k -u admin:netapp1! https://netapp-clusternetappcom/api/application/consistency-groups/6f51748a-0a7f-11ec-a449-005056bbcf9f -d { "namespaces": [ { "name": "/vol/vol1/new_namespace", "space": { "size": "10m" }, "os_type": "windows", "provisioning_options": { "count": 2 }, "subsystem_map": { "subsystem": { "name": "mysubsystem", "hosts": [ { "nqn": "nqn1992-08comnetapp:snd04594ef915b4c73b642169e72e4c0b1:subsystemhost1" }, { "nqn": "nqn1992-08comnetapp:snd04594ef915b4c73b642169e72e4c0b1:subsystemhost2" } ] } } } ] } ` # response: ` { "job": { "uuid": "8c9cabf3-0a88-11ec-a449-005056bbcf9f", "_links": { "self": { "href": "/api/cluster/jobs/8c9cabf3-0a88-11ec-a449-005056bbcf9f" } } } } ` restore a consistency group to the contents of an existing snapshot restore an existing consistency group to the contents of an existing snapshot of the consistency group ` curl -x -k -u admin:netapp1! patch https://netapp-clusternetappcom/api/application/consistency-groups/6f51748a-0a7f-11ec-a449-005056bbcf9f -d { "restore_to": { "snapshot": { "uuid": "92c6c770-17a1-11eb-b141-005056acd498"} } } ` ## response: ` { "job": { "uuid": "8907bd9e-1463-11eb-a719-005056ac70af", "_links": { "self": { "href": "/api/cluster/jobs/8907bd9e-1463-11eb-a719-005056ac70af" } } } } `
PATCH /application/consistency-groups/{uuid}
Introduced In: 9.10
Updates a consistency group.
Note that this operation will never delete storage elements. You can specify only elements that should be added to the consistency group regardless of existing storage objects.
N/A. There are no ONTAP commands for managing consistency groups.
Adding LUNs to an existing volume in an existing consistency group
Adds two NVMe namespaces to an existing volume in an existing consistency group, creates a new subsystem, and binds the new namespaces to it.
curl -X PATCH -k -u admin:netapp1! https://netapp-cluster.netapp.com/api/application/consistency-groups/6f48d798-0a7f-11ec-a449-005056bbcf9f -d '{ "luns": [ { "name": "/vol/vol1/new_luns", "provisioning_options": { "count": 2, "action": "create" }, "space": { "size": "100mb" }, "os_type": "linux", "lun_maps": [ { "igroup": { "name": "igroup2", "initiators": [ { "name": "01:02:03:04:05:06:07:01" } ] } } ] } ] }'
Response:
  "job": {
Adding namespaces to an existing volume in an existing consistency group
Add 2 NVMe Namespaces to an existing volume in an existing consistency group, create a new subsystem and bind the new namespaces to it.
curl -X PATCH -k -u admin:netapp1! https://netapp-cluster.netapp.com/api/application/consistency-groups/6f51748a-0a7f-11ec-a449-005056bbcf9f -d '{ "namespaces": [ { "name": "/vol/vol1/new_namespace", "space": { "size": "10M" }, "os_type": "windows", "provisioning_options": { "count": 2 }, "subsystem_map": { "subsystem": { "name": "mySubsystem", "hosts": [ { "nqn": "nqn.1992-08.com.netapp:sn.d04594ef915b4c73b642169e72e4c0b1:subsystem.host1" }, { "nqn": "nqn.1992-08.com.netapp:sn.d04594ef915b4c73b642169e72e4c0b1:subsystem.host2" } ] } } } ] }'
Response:
  "job": {
Restore a consistency group to the contents of an existing snapshot
Restore an existing consistency group to the contents of an existing snapshot of the consistency group
curl -X -k -u admin:netapp1! PATCH https://netapp-cluster.netapp.com/api/application/consistency-groups/6f51748a-0a7f-11ec-a449-005056bbcf9f' -d '{ "restore_to": { "snapshot": { "uuid": "92c6c770-17a1-11eb-b141-005056acd498"} } }'
Response:
  "job": {
uuid
string
path
True
The unique identifier of the consistency group to modify.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
luns
array[luns]
The LUNs array can be used to create or modify LUNs in a consistency group on a new or existing volume that is a member of the consistency group. LUNs are considered members of a consistency group if they are located on a volume that is a member of the consistency group.
namespaces
array[namespaces]
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the SVM using the NVMe over Fabrics protocol. In ONTAP, an NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
An NVMe namespace is created to a specified size using thin or thick provisioning as determined by the volume on which it is created. NVMe namespaces support being cloned. An NVMe namespace cannot be renamed, resized, or moved to a different volume. NVMe namespaces do not support the assignment of a QoS policy for performance management, but a QoS policy can be assigned to the volume containing the namespace. See the NVMe namespace object model to learn more about each of the properties supported by the NVMe namespace REST API.
An NVMe namespace must be mapped to an NVMe subsystem to grant access to the subsystem's hosts. Hosts can then access the NVMe namespace and perform I/O using the NVMe over Fabrics protocol.
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
  • Introduced in: 9.10
  • x-ntap-modifyOnly: true
parent_consistency_group
The parent consistency group.
Options that are applied to the operation.
qos
qos
replicated
boolean
Indicates whether or not replication has been enabled on this consistency group.
replication_source
boolean
Indicates whether or not this consistency group is the source for replication.
restore_to
restore_to
Use to restore a consistency group to a previous Snapshot copy
snapshot_policy
snapshot_policy_reference
This is a reference to the Snapshot copy policy.
space
space
Space information for the consistency group.
svm
svm_reference
uuid
string
The unique identifier of the consistency group. The UUID is generated by ONTAP when the consistency group is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
Example request
  "luns": [
      "clone": {
        "source": {
          "name": "/vol/volume1/lun1",
      "comment": "string",
      "create_time": "2018-06-04T19:00:00Z",
      "lun_maps": [
          "igroup": {
            "igroups": [
                "name": "igroup1",
            "initiators": [
                "comment": "my comment",
                "name": "iqn.1998-01.com.corp.iscsi:name1"
            "name": "igroup1",
            "os_type": "string",
        "action": "string"
      "qos": {
        "policy": {
          "max_throughput_iops": 10000,
          "max_throughput_mbps": 500,
          "min_throughput_iops": 2000,
          "min_throughput_mbps": 500,
          "name": "performance",
      "serial_number": "string",
      "space": {
        "size": 1073741824,
        "used": 0
  "namespaces": [
        "action": "string"
      "subsystem_map": [
          "anagrpid": "00103050h",
          "nsid": "00000001h",
          "subsystem": {
            "name": "string",
  "parent_consistency_group": {
    "name": "my_consistency_group",
    "action": "string",
    "storage_service": {
      "name": "string"
  "qos": {
    "policy": {
  "restore_to": {
    "snapshot": {
      "name": "string",
      "uuid": "string"
  "snapshot_policy": {
    "name": "default",
  "space": {
    "available": 5737418,
    "size": 1073741824,
    "used": 5737418
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
53411852
A consistency group with the same identifier in the same scope exists.
53411853
Fields provided in the request conflict with each other.
53411856
Field provided is only supported when provisioning new objects.
53411857
LUNs that are not members of the application are not supported by this API. LUNs can be added to an application by adding the volume containing the LUNs to the application.
53411860
An object with the same identifier in the same scope exists.
53411861
Volume specified does not exist in provided volume array.
53411862
Modifying existing igroups is not supported using this API.
53411864
Request content insufficient to add an existing volume to an application.
53411865
Volumes contained in one consistency group can not be added to a different consistency group.
53411866
LUNs are not supported on FlexGroups volumes.
53411867
LUN name is too long after appending a unique suffix.
53411869
Volume name is too long after appending a unique suffix.
53411870
When using the "round_robin" layout, the volume count must not be greater than the LUN count.
string
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
name
string
The fully qualified path name of the clone source LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH.
uuid
string
The unique identifier of the clone source LUN. Valid in POST and PATCH.
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
Persistent reservations for the patched LUN are also preserved.
source
source
igroups
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiators
The initiators that are members of the initiator group.
comment
string
A comment available for use by the administrator.
name
string
Name of initiator that is a member of the initiator group.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
igroups
array[igroups]
Separate igroup definitions to include in this igroup.
initiators
array[initiators]
The initiators that are members of the group.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
uuid
string
lun_maps
A LUN map is an association between a LUN and an initiator group.
When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
action
string
Operation to perform
count
integer
Number of elements to perform the operation on.
policy
The QoS policy
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos
policy
policy
The QoS policy
space
The storage space related properties of the LUN.
size
integer
The total provisioned size of the LUN. The LUN size can be increased but not reduced using the REST interface. The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The actual minimum and maxiumum sizes vary depending on the ONTAP version, ONTAP platform, and the available space in the containing volume and aggregate. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
  • example: 1073741824
  • format: int64
  • Max value: 140737488355328
  • Min value: 4096
  • Introduced in: 9.6
used
integer
The amount of space consumed by the main data stream of the LUN.
This value is the total space consumed in the volume by the LUN, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways SAN filesystems and applications utilize blocks within a LUN, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the LUN blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
luns
A LUN is the logical representation of storage in a storage area network (SAN).
In ONTAP, a LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
A LUN can be created to a specified size using thin or thick provisioning. A LUN can then be renamed, resized, cloned, and moved to a different volume. LUNs support the assignment of a quality of service (QoS) policy for performance management or a QoS policy can be assigned to the volume containing the LUN. See the LUN object model to learn more about each of the properties supported by the LUN REST API.
A LUN must be mapped to an initiator group to grant access to the initiator group's initiators (client hosts). Initiators can then access the LUN and perform I/O over a Fibre Channel (FC) fabric using the Fibre Channel Protocol or a TCP/IP network using iSCSI.
clone
clone
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
create_time
string
The time the LUN was created.
enabled
boolean
The enabled state of the LUN. LUNs can be disabled to prevent access to the LUN. Certain error conditions also cause the LUN to become disabled. If the LUN is disabled, you can consult the state property to determine if the LUN is administratively disabled (offline) or has become disabled as a result of an error. A LUN in an error condition can be brought online by setting the enabled property to true or brought administratively offline by setting the enabled property to false. Upon creation, a LUN is enabled by default. Valid in PATCH.
lun_maps
array[lun_maps]
An array of LUN maps.
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
qos
qos
serial_number
string
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
  • maxLength: 12
  • minLength: 12
  • readOnly: 1
space
space
uuid
string
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
  • readOnly: 1
nvme_subsystem_reference
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts.
name
string
The name of the NVMe subsystem.
uuid
string
The unique identifier of the NVMe subsystem.
subsystem_map
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems.
There is an added cost to retrieving property values for subsystem_map. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter.
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
namespaces
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the storage virtual machine using the NVMe over Fabrics protocol.
auto_delete
boolean
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones.
When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new NVMe namespace is false.
There is an added cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
comment
string
create_time
string
The time the NVMe namespace was created.
enabled
boolean
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, you can check the state property to determine what error disabled the namespace. An NVMe namespace is enabled automatically when it is created.
subsystem_map
array[subsystem_map]
uuid
string
The unique identifier of the NVMe namespace.
name
string
The name of the consistency group.
uuid
string
storage_service
Determines the placement of any storage object created during this operation.
name
string
Storage service name. If not specified, the default value is the most performant for the platform.
action
string
storage_service
storage_service
snapshot
A consistency group's Snapshot copy
name
string
The name of the consistency group's Snapshot copy to restore to.
uuid
string
The UUID of the consistency group's Snapshot copy to restore to.
restore_to
snapshot
snapshot
name
string
uuid
string
space
available
integer
The amount of space available in the consistency group, in bytes.
size
integer
The total provisioned size of the consistency group, in bytes.
used
integer
The amount of space consumed in the consistency group, in bytes.
svm_reference
name
string
The name of the SVM.
uuid
string
tiering
The tiering placement and policy definitions for volumes in this consistency group.
control
string
Storage tiering placement rules for the object.
action
string
count
integer
storage_service
storage_service
qos
The QoS policy for this volume.
policy
policy
The QoS policy
space
available
integer
The available space, in bytes.
used
integer
The virtual space used (includes volume reserves) before storage efficiency, in bytes.
tiering
The tiering placement and policy definitions for this volume.
control
string
volumes
comment
string
A comment for the volume. Valid in POST or PATCH.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroups, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
qos
qos
snapshot_policy
space
space
tiering
tiering
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.8
consistency_groups
luns
array[luns]
namespaces
array[namespaces]
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
qos
qos
restore_to
restore_to
snapshot_policy
space
space
svm
svm_reference
uuid
string
  • readOnly: 1
consistency_group
luns
array[luns]
namespaces
array[namespaces]
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
qos
qos
replicated
boolean
replication_source
boolean
restore_to
restore_to
snapshot_policy
space
space
svm
svm_reference
uuid
string
  • readOnly: 1
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
