REST API reference
Update a consistency group
PATCH /application/consistency-groups/{uuid}
Introduced In: 9.10
Updates a consistency group.
Note that this operation will never delete storage elements. You can specify only elements that should be added to the consistency group regardless of existing storage objects.
N/A. There are no ONTAP commands for managing consistency groups.
uuid
string
path
True
The unique identifier of the consistency group to modify.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
application
application
consistency_groups
array[consistency_groups]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A consistency group can only be associated with one direct parent consistency group.
luns
array[luns]
The LUNs array can be used to create or modify LUNs in a consistency group on a new or existing volume that is a member of the consistency group. LUNs are considered members of a consistency group if they are located on a volume that is a member of the consistency group.
namespaces
array[namespaces]
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the SVM using the NVMe over Fabrics protocol. In ONTAP, an NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
An NVMe namespace is created to a specified size using thin or thick provisioning as determined by the volume on which it is created. NVMe namespaces support being cloned. An NVMe namespace cannot be renamed, resized, or moved to a different volume. NVMe namespaces do not support the assignment of a QoS policy for performance management, but a QoS policy can be assigned to the volume containing the namespace. See the NVMe namespace object model to learn more about each of the properties supported by the NVMe namespace REST API.
An NVMe namespace must be mapped to an NVMe subsystem to grant access to the subsystem's hosts. Hosts can then access the NVMe namespace and perform I/O using the NVMe over Fabrics protocol.
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
  • Introduced in: 9.10
provisioning_options
Options that are applied to the operation.
qos
qos
restore_to
restore_to
Use to restore a consistency group to a previous Snapshot copy
snapshot_policy
snapshot_policy_reference
This is a reference to the Snapshot copy policy.
volumes
array[volumes]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A volume can only be associated with one direct parent consistency group.
The volumes array can be used to create new volumes in the consistency group, add existing volumes to the consistency group, or modify existing volumes that are already members of the consistency group.
The total number of volumes across all child consistency groups contained in a consistency group is constrained by the same limit.
Example request
  "application": {
    "component_type": "string",
    "type": "string"
  "consistency_groups": [
      "application": {
        "type": "string"
      "luns": [
          "clone": {
            "source": {
              "name": "/vol/volume1/lun1",
          "comment": "string",
          "create_time": "2018-06-04T19:00:00Z",
          "enabled": true,
          "lun_maps": [
              "igroup": {
                "igroups": [
                    "name": "igroup1",
                "initiators": [
                    "comment": "my comment",
                    "name": "iqn.1998-01.com.corp.iscsi:name1"
                "name": "igroup1",
                "os_type": "string",
          "provisioning_options": {
            "action": "string"
          "serial_number": "string",
          "space": {
            "guarantee": {
              "reserved": true
            "size": 1073741824
      "namespaces": [
            "action": "string"
          "space": {
            "guarantee": {
              "reserved": true
            "size": 1073741824
          "subsystem_map": {
            "anagrpid": "00103050h",
            "nsid": "00000001h",
            "subsystem": {
        "action": "string",
        "storage_service": {
          "name": "string"
      "qos": {
        "policy": {
          "max_throughput_iops": 10000,
          "max_throughput_mbps": 500,
          "min_throughput_iops": 2000,
          "min_throughput_mbps": 500,
          "name": "performance",
      "restore_to": {
        "snapshot": {
          "name": "string",
          "uuid": "string"
      "snapshot_policy": {
        "name": "default",
      "volumes": [
          "name": "vol_cs_dept",
          "nas": {
            "cifs": {
              "shares": [
                  "comment": "HR Department Share",
                  "dir_umask": 22,
                  "file_umask": 22,
                  "home_directory": true,
                  "offline_files": "string",
                  "unix_symlink": "string",
                  "vscan_profile": "string"
            "export_policy": {
              "name": "string",
              "rules": [
                  "anonymous_user": "string",
                  "chown_mode": "string",
                  "clients": [
                      "match": "0.0.0.0/0"
                  "ntfs_unix_security": "string",
                  "protocols": [
                    "string"
                  "ro_rule": [
                    "string"
                  "rw_rule": [
                    "string"
                  "superuser": [
                    "string"
              "uuid": "string"
            "action": "string",
              "name": "string"
          "qos": {
            "policy": {
            "name": "default",
          "tiering": {
            "control": "string",
            "object_stores": [
                "name": "string"
  "luns": [
      "clone": {
        "source": {
      "enabled": true,
      "lun_maps": [
          "igroup": {
            "igroups": [
                "name": "igroup1",
            "initiators": [
            "name": "igroup1",
        "action": "string"
      "space": {
        "guarantee": {
          "reserved": true
        "size": 1073741824
  "namespaces": [
        "action": "string"
      "space": {
        "guarantee": {
          "reserved": true
        "size": 1073741824
      "subsystem_map": {
        "subsystem": {
    "action": "string",
      "name": "string"
  "qos": {
    "policy": {
  "replicated": true,
  "replication_source": true,
  "restore_to": {
    "snapshot": {
      "name": "string",
      "uuid": "string"
    "name": "default",
  "volumes": [
      "nas": {
        "cifs": {
          "shares": [
              "dir_umask": 22,
              "file_umask": 22,
        "export_policy": {
          "name": "string",
          "rules": [
              "clients": [
              "protocols": [
                "string"
              "ro_rule": [
                "string"
              "rw_rule": [
                "string"
              "superuser": [
                "string"
          "uuid": "string"
        "action": "string",
          "name": "string"
      "qos": {
        "policy": {
        "name": "default",
      "tiering": {
        "object_stores": [
            "name": "string"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
53411852
A consistency group with the same identifier in the same scope exists.
53411853
Fields provided in the request conflict with each other.
53411856
Field provided is only supported when provisioning new objects.
53411857
LUNs that are not members of the application are not supported by this API. LUNs can be added to an application by adding the volume containing the LUNs to the application.
53411860
An object with the same identifier in the same scope exists.
53411861
Volume specified does not exist in provided volume array.
53411862
Modifying existing igroups is not supported using this API.
53411864
Request content insufficient to add an existing volume to an application.
53411865
Volumes contained in one consistency group cannot be added to a different consistency group.
53411866
LUNs are not supported on FlexGroup volumes.
53411867
LUN name is too long after appending a unique suffix.
53411869
Volume name is too long after appending a unique suffix.
53411870
When using the "round_robin" layout, the volume count must not be greater than the LUN count.
string
application
component_type
string
Nested consistency group tag.
type
string
Top level consistency group tag.
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
parent_consistency_group
Consistency group that is to be cloned.
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
parent_snapshot
name
string
Name of an existing Snapshot copy of a parent consistency group.
volume
Volume name suffix/prefix for the cloned volumes.
prefix
string
Volume name prefix for cloned volumes.
suffix
string
Volume name suffix for cloned volumes.
clone
Creates a clone of an existing consistency group from the current contents or an existing Snapshot copy.
guarantee
guarantee
parent_snapshot
parent_snapshot
split_initiated
boolean
Splits volumes after cloning. Default is false.
volume
volume
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
name
string
The fully qualified path name of the clone source LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH.
uuid
string
The unique identifier of the clone source LUN. Valid in POST and PATCH.
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
Persistent reservations for the patched LUN are also preserved.
source
source
igroups
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiators
The initiators that are members of the initiator group.
comment
string
A comment available for use by the administrator.
name
string
Name of initiator that is a member of the initiator group.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
igroups
array[igroups]
Separate igroup definitions to include in this igroup.
initiators
array[initiators]
The initiators that are members of the group.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
uuid
string
lun_maps
A LUN map is an association between a LUN and an initiator group.
When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
action
string
Operation to perform
count
integer
Number of elements to perform the operation on.
policy
The QoS policy
qos
policy
policy
The QoS policy
guarantee
Properties that request and report the space guarantee for the LUN.
requested
boolean
The requested space reservation policy for the LUN. If true, a space reservation is requested for the LUN; if false, the LUN is thin provisioned. Guaranteeing a space reservation request for a LUN requires that the volume in which the LUN resides is also space reserved and that the fractional reserve for the volume is 100%. Valid in POST and PATCH.
space
The storage space related properties of the LUN.
guarantee
guarantee
size
integer
The total provisioned size of the LUN. The LUN size can be increased but not reduced using the REST interface. The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The actual minimum and maxiumum sizes vary depending on the ONTAP version, ONTAP platform, and the available space in the containing volume and aggregate. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
  • example: 1073741824
  • format: int64
  • Max value: 140737488355328
  • Min value: 4096
  • Introduced in: 9.6
luns
A LUN is the logical representation of storage in a storage area network (SAN).
In ONTAP, a LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
A LUN can be created to a specified size using thin or thick provisioning. A LUN can then be renamed, resized, cloned, and moved to a different volume. LUNs support the assignment of a quality of service (QoS) policy for performance management or a QoS policy can be assigned to the volume containing the LUN. See the LUN object model to learn more about each of the properties supported by the LUN REST API.
A LUN must be mapped to an initiator group to grant access to the initiator group's initiators (client hosts). Initiators can then access the LUN and perform I/O over a Fibre Channel (FC) fabric using the Fibre Channel Protocol or a TCP/IP network using iSCSI.
clone
clone
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
create_time
string
The time the LUN was created.
lun_maps
array[lun_maps]
An array of LUN maps.
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
qos
qos
serial_number
string
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
  • maxLength: 12
  • minLength: 12
  • readOnly: 1
space
space
uuid
string
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
guarantee
Properties that request and report the space guarantee for the NVMe namespace.
requested
boolean
The requested space reservation policy for the NVMe namespace. If true, a space reservation is requested for the namespace; if false, the namespace is thin provisioned. Guaranteeing a space reservation request for a namespace requires that the volume in which the namespace resides also be space reserved and that the fractional reserve for the volume be 100%.
The space reservation policy for an NVMe namespace is determined by ONTAP.
  • x-nullable: true
space
The storage space related properties of the NVMe namespace.
guarantee
guarantee
size
integer
The total provisioned size of the NVMe namespace. Valid in POST and PATCH. The NVMe namespace size can be increased but not reduced using the REST interface.
The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The maximum size is variable with respect to large NVMe namespace support in ONTAP. If large namespaces are supported, the maximum size is 128 TB (140737488355328 bytes) and if not supported, the maximum size is just under 16 TB (17557557870592 bytes). The minimum size supported is always 4096 bytes.
  • format: int64
  • Min value: 4096
status
Status information about the NVMe namespace.
consistency_group_nvme_host
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
consistency_group_nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
comment
string
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.
uuid
string
The unique identifier of the NVMe subsystem.
subsystem_map
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems.
There is an added computational cost to retrieving property values for subsystem_map. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter.
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
namespaces
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the storage virtual machine using the NVMe over Fabrics protocol.
auto_delete
boolean
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones.
When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new NVMe namespace is false.
comment
string
create_time
string
The time the NVMe namespace was created.
enabled
boolean
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, you can check the state property to determine what error disabled the namespace. An NVMe namespace is enabled automatically when it is created.
space
space
subsystem_map
subsystem_map
uuid
string
The unique identifier of the NVMe namespace.
The parent consistency group.
name
string
uuid
string
storage_service
Determines the placement of any storage object created during this operation.
name
string
Storage service name. If not specified, the default value is the most performant for the platform.
action
string
storage_service
storage_service
policy
The QoS policy
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
snapshot
A consistency group's Snapshot copy
name
string
The name of the consistency group's Snapshot copy to restore to.
uuid
string
The UUID of the consistency group's Snapshot copy to restore to.
restore_to
snapshot
snapshot
name
string
uuid
string
space
Space information for the consistency group.
available
integer
The amount of space available in the consistency group, in bytes.
size
integer
The total provisioned size of the consistency group, in bytes.
used
integer
The amount of space consumed in the consistency group, in bytes.
svm
The Storage Virtual Machine (SVM) in which the consistency group is located.
name
string
The name of the SVM.
uuid
string
object_stores
name
string
The name of the object store to use. Used for placement.
tiering
The tiering placement and policy definitions for volumes in this consistency group.
control
string
Storage tiering placement rules for the object.
object_stores
array[object_stores]
Object stores to use. Used for placement.
acls
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
consistency_group_cifs_share
CIFS share is a named access point in a volume. Before users and applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permission. CIFS shares are tied to the CIFS server on the SVM. When a CIFS share is created, ONTAP creates a default ACL for the share with Full Control permissions for Everyone.
_links
_links
access_based_enumeration
boolean
Specifies whether all folders inside this share are visible to a user based on that individual user's access right; prevents the display of folders or other shared resources that the user does not have access to.
allow_unencrypted_access
boolean
Specifies whether or not the SMB2 clients are allowed to access the encrypted share.
change_notify
boolean
Specifies whether CIFS clients can request for change notifications for directories on this share.
comment
string
Specify the CIFS share descriptions.
continuously_available
boolean
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback.
dir_umask
integer
Directory mode creation mask to be viewed as an octal number.
encryption
boolean
Specifies whether SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share.
file_umask
integer
File mode creation mask to be viewed as an octal number.
namespace_caching
boolean
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers.
no_strict_security
boolean
Specifies whether or not CIFS clients can follow Unix symlinks outside the share boundaries.
offline_files
string
Offline Files The supported values are:
  • none - Clients are not permitted to cache files for offline access.
  • manual - Clients may cache files that are explicitly selected by the user for offline access.
  • documents - Clients may automatically cache files that are used by the user for offline access.
  • programs - Clients may automatically cache files that are used by the user for offline access and may use those files in an offline mode even if the share is available.
oplocks
boolean
Specifies whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations.
show_snapshot
boolean
Specifies whether or not the Snapshot copies can be viewed and traversed by clients.
unix_symlink
string
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
  • local - Enables only local symbolic links which is within the same CIFS share.
  • widelink - Enables both local symlinks and widelinks.
  • disable - Disables local symlinks and widelinks.
vscan_profile
string
Vscan File-Operations Profile The supported values are:
  • no_scan - Virus scans are never triggered for accesses to this share.
  • standard - Virus scans can be triggered by open, close, and rename operations.
  • strict - Virus scans can be triggered by open, read, close, and rename operations.
  • writes_only - Virus scans can be triggered only when a file that has been modified is closed.
cifs
shares
array[consistency_group_cifs_share]
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rules
allow_device_creation
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
export_policy
The policy associated with volumes to export them for protocol access.
name
string
Name of the export policy.
rules
array[export_rules]
The set of rules that govern the export policy.
uuid
string
Identifier for the export policy.
junction_parent
name
string
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume.
uuid
string
Unique identifier for the parent volume.
nas
The CIFS share policy and/or export policies for this volume.
cifs
cifs
export_policy
export_policy
action
string
count
integer
storage_service
storage_service
qos
The QoS policy for this volume.
policy
policy
The QoS policy
space
size
integer
Total provisioned size, in bytes.
tiering
The tiering placement and policy definitions for this volume.
control
string
object_stores
volumes
comment
string
A comment for the volume. Valid in POST or PATCH.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroups, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
nas
nas
qos
qos
snapshot_policy
space
space
tiering
tiering
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.8
consistency_groups
application
application
luns
array[luns]
namespaces
array[namespaces]
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
qos
qos
restore_to
restore_to
snapshot_policy
volumes
array[volumes]
svm
_links
_links
name
string
uuid
string
consistency_group
application
application
consistency_groups
luns
array[luns]
namespaces
array[namespaces]
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
qos
qos
restore_to
restore_to
snapshot_policy
volumes
array[volumes]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
