Update the state of an asynchronous job
Updates the state of a specific asynchronous job to reflect its current progress or completion status. This helps in managing long-running operations that require tracking and control.
HTTP method and endpoint
PATCH /cluster/jobs/{uuid}
Introduced in
ONTAP 9.6
uuid |
string |
path |
True |
Job UUID |
action |
string |
query |
False |
Requests a job to pause, resume, or cancel. Note that not all jobs support these actions. A job can only be resumed if it is in a paused state. After you successfully request a job to be cancelled, the job state changes to either success or failure.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
459753 |
Command execution failed with custom error from the program. |
458762 |
Job is already in a terminal state. |
458773 |
The Job Manager is not initialized. |
458771 |
The specified job is running. |
458776 |
The specified job is not currently running. |
458783 |
This job does not support pause. |
458784 |
This job does not support cancel. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
