REST API reference
Update the state of an asynchronous job
Updates the state of a specific asynchronous job to manage its progress or handle any necessary changes during its execution.
HTTP method and endpoint
PATCH /cluster/jobs/{uuid}
Introduced in
ONTAP 9.6
uuid
string
path
True
Job UUID
action
string
query
False
Requests a job to pause, resume, or cancel. Note that not all jobs support these actions. A job can only be resumed if it is in a paused state. After you successfully request a job to be cancelled, the job state changes to either success or failure.
  • enum: ["pause", "resume", "cancel"]
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
458762
Job is already in a terminal state.
458773
The Job Manager is not initialized.
458771
The specified job is running.
458776
The specified job is not currently running.
458783
This job does not support pause.
458784
This job does not support cancel.
Name Type Description
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
